Gentlemen, what’s up?
Is there any way to filter the logs received in Graylog?
I’m asking because of my scenario, where I’m receiving logs from Vmware EXSI, and there are a lot of them every day… which quickly fills up the SRV Graylog disk…
Absolutly! If you have a pipeline rule wirh something in the when clause measage_type = something I dont care about, and in the then clause you have the function drop_mesaage, then those messages will be dropped and never be stored.
Is there a step-by-step document on how to do it?
Hey @badaroed
First setup you Pipeline.
https://go2docs.graylog.org/5-0/making_sense_of_your_log_data/pipelines.html
The pipeline page you need name the pipeline, attach the stream and add the rule.
Example of pipeline rule
rule “Drop Syslog Messages”
has_field("level") AND
( to_string($message.level) == “7” OR
lowercase(to_string($message.level)) == "debug" )
drop_message();
