How to delete sidecar
  • OS Information:
    Ubuntu 22
  • Package Version:
    5.1
Set the sidecars configuration expiration to 1 min
I am still not able to delete the sidecars even though I set the threashold to 1 min.
I believe there was a caching bug that caused that setting to not take effect right away. I think if you restart the Graylog service they will be purged.
yes restarting the service fixed the issue.
