Is there any way to add notification using API ? just like creating stream using “/api/streams” uri POST method.
check the API browser (/api/api-browser) and you will discover /api/api-browser#!/Alerts
Hi Jan,
Thank you for looking into this, please find attached screen shot I dont find POST method to create Alerts on /api/api-browser#!/Alerts URI. similarly on notification.
If it is there can you share me the complete url to create Alerts and Notification please.
-Shakeel.
Look at the Stream/* endpoints. cause alerts are bound to a stream.
