How to configure graylog to display logs from elasticsearch
I am newbie to graylog and I am trying to setup graylog to display application logs in the graylog UI. Tools used are graylog, elasticsearch and filebeat.
  1. I have installed and configured the graylog in server-A and able to open the webpage and login with admin credentials.
  2. I have installed and configured elasticsearch in the same server (server-A) where graylog is running and able to see the below message in the graylog UI.
    “Elasticsearch cluster graylog is green.”
  3. I have installed and configured filebeat on server-B and able to push the output (logs) to elasticsearch and can see the document count is getting increased by running the below command.
    "curl -XGET “elasticsearch-host:9200/_cat/indices?v”
Now I want to configure graylog to fetch those logs from the elasticsearch and display it in graylog UI.
I am not sure what to configure here, whether it is input or indices?
FYI: I am not using any logstash or sidecar.
  • OS Information: RHEL 7.9
  • Package Version: graylog - 5.1.3-1, elasticsearch - 7.17.11-1, filebeat - 7.17.0
    Graylog’s server.conf
is_leader = true
password_secret = <token>
root_password_sha2 = <token>
root_timezone = UTC
data_dir = /data1/graylog/lib/graylog-server
http_bind_address = <graylog_server_ip>:9000
http_enable_cors = true
elasticsearch_hosts = http://<elasticsearch_hosts_ip>:9200
allow_highlighting = false
output_batch_size = 500
output_flush_interval = 1
processbuffer_processors = 5
outputbuffer_processors = 3
ring_size = 65536
inputbuffer_ring_size = 65536
inputbuffer_processors = 2
message_journal_dir = /data1/graylog/lib/graylog-server/journal
elasticsearch.yml
cluster.name: graylog
path.data: /var/lib/elasticsearch
path.logs: /var/log/elasticsearch
network.host: 0.0.0.0
discovery.seed_hosts: ["127.0.0.1"]
action.auto_create_index: .monitoring*,.watches,.triggered_watches,.watcher-history*,.ml*
filebeat.yml
filebeat.inputs:
- type: log
  enabled: true
  paths:
    - /home/webservices/nginx/logs/*.log
    - /data1/var/logs/*.log
    #- /var/log/*.log
    #- /var/log/messages
    #- c:\programdata\elasticsearch\logs\*
filebeat.config.modules:
  # Glob pattern for configuration loading
  path: ${path.config}/modules.d/*.yml
  # Set to true to enable config reloading
  reload.enabled: false
  # Period on which files under path should be checked for changes
  #reload.period: 10s
# ======================= Elasticsearch template setting =======================
setup.ilm.overwrite: true
setup.template.overwrite: true
setup.template.settings:
  index.number_of_shards: 1
  index.number_of_replicas: 0
  #index.codec: best_compression
  #_source.enabled: false
setup.kibana:
# ---------------------------- Elasticsearch Output ----------------------------
output.elasticsearch:
  # Array of hosts to connect to.
  hosts: ["http://<elasticsearch_server_ip>:9200"]
  # Protocol - either `http` (default) or `https`.
  #protocol: "https"
  # Authentication credentials - either API key or username/password.
  #api_key: "id:api_key"
  #username: "elastic"
  #password: "changeme"
# ================================= Processors =================================
processors:
  - add_host_metadata:
      when.not.contains.tags: forwarded
  - add_cloud_metadata: ~
  - add_docker_metadata: ~
  - add_kubernetes_metadata: ~
I tried to configure input and indices but nothing works.
I want to see the logs sent by filebeat in graylog.
With graylog you will send the log message to graylog itself and not to elasticsearch.
I recommend using OpenSearch instead though as graylog only supports up to Elasticsearch 7.10.2. It is not compatible with Elasticsearch 7.17. In the near future support for Elasticsearch will be dropped entirely.
In case you want a quick copy/paste commands guide, check out https://github.com/Graylog2/se-poc-docs/tree/main/src/On%20Prem%20POC
Regarding configuring beats, you’ll need a beats input in your graylog cluster. You can send logs from beats to a graylog beat input using the following:
output.logstash:
   hosts: ["servername.domain.tld:5044"]
Note that TCP Port 5044 is the default beat port, but is customizable. Make sure it matches the port you configured on your graylog beats input.
Hope that helps!
So, do I need to install logstash? and what version of opensearch and filebeat is recommended for graylog 5.1.3-1?
Now I have downgraded all versions
Graylog - 4.2.5-1
elasticsearch - 7.9.2-1
mongodb - 4.4.23-1
But still I cannot see any log messages for the input type “Beats” in graylog dashboard.
no, filebeat will use the logstash output but sends to graylog.
The latest versions of both should work ok.
Can you confirm you have sources sending via the logstashoutput to your beats input on graylog? Do you see any messages for your beat input?
No, I don’t see any messages…
Can you verify your log source can reach your graylog server on that port, and can you check via tcpdump? For example: via your graylog server sudo tcpdump -i eth0 -nA port 5044 . This will show realtime traffic on that port.
Also do you see any errors in the filebeat log? It will show an indication if it can or cannot reach the configured output.
    "log.level": "debug",
    "@timestamp": "2023-07-31T15:08:05.475Z",
    "log.logger": "logstash",
    "log.origin": {
        "file.name": "logstash/async.go",
        "file.line": 172
    "message": "1 events out of 1 events sent to logstash host 127.0.0.1:5044. Continue sending",
    "service.name": "filebeat",
    "ecs.version": "1.6.0"
@drewmiranda-gl , Thank a ton…
The issue got resolved. The hosts of output.logstash had URL with “http://” and after removing this I am able to see the logs in graylog dashboard.
