How much server resources enough for graylog single instace?
I have set up graylog, ES and mongodb on a redhat server (RAM 16, 4 CPU) to get the log that output from .Netframework application that hosted on windows server, i wonder if it is enough or not?
can you give me sample config for single instance like this?
I am using virtual machine RAM 4 GB, CPU 2 cores, CentOS 7, about 280 MB daily data. Generally OK. Storage requirements are documented here https://docs.graylog.org/en/3.3/pages/getting_started/planning.html#retention
thank @Karlis. now it is working stable.
