How important is it *really* to have 2 servers?
Doing budget forecasting, planning to implement Graylog next year, and trying to estimate our hardware costs to do so. Our organization is very small, we anticipate only 5-10gb of log ingestion per day. The docs suggest that at that scale we ought to have 2 (physical!?) servers, one for Graylog with 8 cores and 16GB of RAM, and one for Data Node with 8 cores and 24GB of RAM. Is there any reason I shouldn’t just build one big hypervisor with enough cores and ram for both and spin up a VM for each of those?
Given that it’s hard to even find a server cpu with less than 12 cores, it kind of seems like the docs are written with the assumption I’ll be virtualizing, but I don’t know if there’s some other concern I’m missing. Thanks for your guidance!
n/a
  • TBD
Reading the manual
Please sanity-check my understanding of this topic and explain if I’ve misunderstood something.
Hey @Nchitech1,
It’s guidance only, it helps for things like troubleshooting and resource contention. Given the ingest would be low a single server with a hypervisor installed would be the best route assuming redundancy is not something your after. That way you could potentially use any remaining compute for other tasks.
