How can i check "falling collector"
Colletors “Falling”
I have some failed collectors. But what i see “they collecting Data” i think it works . How can i fix this ? Where i have to search.
Operating system information
2.4.1
Update in moment not possible
It has been a while but I am pretty sure the collector has a log area on the client in the same area that the collector is installed. The newer collectors (called sidecars) have a path like this: C:\Program Files\Graylog\sidecar\logs and there is usually enough info in the log files there to tell you what is going on.
More information when you are asking questions is always helpful… Environment, errors, what have you tried… also - use the formatting tools in the post GUI (like </> for code)
