I am writing a new plugin and I want to add a custom validation for a text field to check for a particular format and display in the UI itself before saving the Input. Is there any way to do this check ?
please do not post the same question twice
When someone can answer your question you will get an answer posting the same multiple times does not help.
I close this now.
