How i can add custom fields
HI everyone. How i can add custom fields (on screenshot), google can’t give me answer.
You need to create extrators:
http://docs.graylog.org/en/latest/pages/extractors.html
But, i don’t understand how use extractors.
Then the first thing to do, is to read the documentation. All documentation you can find. And then experiment and learn. And then read some blog posts or articles by people who’ve worked with extractors. And then probably learn the basics of regexp. And then you’ll get it to work!
Or alternatively, hire someone to do it for you :wink:
thx for help. is solved.
