Hi all,
Has anyone had any success using a hosted ElasticSearch soluton with Graylog such as Azure Search or similar service?
Thanks!
Hi all,
Thanks!
People are successfully using AWS Elasticsearch Service and Elastic Cloud with Graylog.
As long as the services are API-compatible with Elasticsearch 5.x and allow access to their indices and cluster APIs, there should be no problem.
