Hi all,
I need to do integrity check on my log data to make sure it wasn’t tempered with. It’s using filebeat. Is there a hash_hmac function in pipeline? I only see sha256.
Ideally, it should be something like, hash_hmac('sha256', $logdata, $key);
There are more than sha256 pipeline function like md5, sha1, sha256, crc32, crc32c, murmur3_32, murmur3_128. Maybe this would work for you?
rule "digest check" when sha256(to_string($message.message)) == to_string($message.digest) then set_field("digest_ok", true) end
not really…it has to be hmac sha256…with a key.
