Help to generate a certificate for my graylog 3.1 ova installation
Hallo,
i need Help to generate a certificate for my graylog 3.1 ova installation
Despite all the guides read I was not able to generate a certificate and to install it on my virtual machine starting from a clean installation of the image ova version 3.1
does a script exist on the net that can help me solve my problem?
A script as it was possible to use in previous versions like 2.4.6 using the commands sudo graylog-ctl enforce-ssl and
sudo graylog-ctl reconfigure?
I also tried to download the certificate and the key from the old installation in version 2.4.6, in this way the access to the web interface in https works but if I try to go and see the status and characteristics of my active node I don’t it is allowed and I hear the wording of a problem to do this activity
Thanks for your help
