I have a strange problem with a GROK pattern.
The GROK pattern
HTTPLOG:
%{IP:client_ip} - - [%{HTTPDATE:timestamp}] “%{WORD:http_method} %{URIPATHPARAM:request_path} HTTP/%{NUMBER:http_version}” %{NUMBER:http_code} %{NUMBER:response_size}?
is applied in a rule to incoming log messages.
I get a lot of (in 30 minutes ~ 300000) processing failures with this message:
failure_details
Value <26/Feb/2025:09:26:42 +0100> caused exception: Invalid format: “26/Feb/2025:09:26:42 +0100” is malformed at “/Feb/2025:09:26:42 +0100”.
failure_type
processing
message
Failed to process message with id ‘01JN0NWQBP04RJH43RNNS4CFD6’: Replaced invalid timestamp value in message <89a3ea50-f41b-11ef-9e5f-0050568773de> with current time
Here is an example of a log message which fails:
10.1.1.68 - - [26/Feb/2025:10:08:45 +0100] “GET /webviewer/rest/documents/999PO1999_RB_7a6d31aaaa1a4ce2b540fad8d0b76ac6/content?sapdocid=7a6d31aaaa1a4ce2b540fad8d0b76ac6&contrep=RB&alurl=https%3A%2F%2FVHSAPP0150.SAP-P.D001.LOC%3A44395%2Fsap%2Fopu%2Fodata%2FGKV%2FCA01_COMLINE_SRV%2FImageSet%28ContRep%3D%27CB%27%2CArcDocId%3D%277a6d31aaaa1a4ce2b540fad8d0b76ac6%27%2CComponent%3D%27%27%2CApp%3D%27%252AGKV%252ACM00A%27%29%2F%24value&token=eyJhbGciOiJIUzUxMiJ9.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.CAUOt66t3HhslpiZ8pMvuCYyF2a1P3EmVRENZWrGUYOVZoCK148zxTfeOtgWaix480QtO_Z6fs9fVMOVqqixHw&nocache=true&page_range=-1&ot=OSCARE_DOC HTTP/1.1” 200 127572
If I go to Test grok patterns and test the GROK pattern from above with this log message it works!!! I get no error!
Does somebody has an idea what’s wrong here?
OS Information: RedHat Linux
Graylog 6.1.5
