Grok pattern for sonicwall firewall logs
can someone help me creating grok pattern for SonicWALL firewall logs?
yes… “someone” can… but you really should just take a sample of the logs, look online for grok tutorials/debuggers and figure it out. You learn more and you can always post specific questions that someone can help with.
Here’s a couple of resources.
http://docs.graylog.org/en/3.1/pages/extractors.html#using-grok-patterns-to-extract-data
https://grokconstructor.appspot.com/
https://grokdebug.herokuapp.com/
g’luck
Hi Cawfehman
thanks for your reply and info, i really appreciate that, i have below example can you help me creating grok pattern for below line
src=10.0.0.3:53898:X1:win10comp-151
Thank you
What are you trying to extract? The IP address? The port? Something else?
Hi Cawfehman
i was trying to extract all of it as source interface, i was able to achieve it by using src=%{NOTSPACE:SourceInterface}. thanks for your help.
Cool… well done… good luck
