Hi Everyone
Let me start off by saying thank you to all the contributors who makes this such a great product!
I am very new to graylog, and have gotten a few basic things going. But I have been struggling to get this use-case solved for three days straight without any success.
What I am trying to do
Easy (for other people) - take the IP from an incoming HAProxy log, get the co-ordinates associated with said IP address, and plot these co-ordinates on a map in Grafana.
What I have done
- I have 2 streams set up currently. One stream for all apache logs, and one for haproxy logs. Streams are distinguished based on
source
of log sender. - I have installed the GeoLite2 database in
/etc/graylog/server/GeoLite2-City.mmdb
- I have set up a Lookuptable, a cache, and a data-adapter. I have gotten zero errors from any of these setups so I assume they are correct.
- I have created a pipeline called ‘HAProxy Geolocation Data’. This pipeline has two stages: Stage0 contains a rule called ‘HAProxy get client IP’ and Stage1 contains a rule called ‘GeoIP lookup: *clientip’.
Example log line input
haproxy[806]: REDACTED_IP:51931 [18/Aug/2020:04:20:23.163] FRONTEND-NEXTCLOUD~ BACKEND-NEXTCLOUD/REDACTED_FQDN 0/0/1/507/508 207 1178 - - --NI 1/1/0/1/0 0/0 "PROPFIND /remote.php/dav/files/my/files HTTP/1.1"
Content of ‘HAProxy get client IP’:
rule "HAProxy get client IP"
has_field("message")
let message_field = to_string($message.message);
let placeholder = grok(pattern: ": %{IPV4}:", value: message_field, only_named_captures: true);
set_field("src_ip",to_ip(placeholder.IP));
I know the match is not refined enough. I will refine it to a “finer” match once I know the data is actually being retrieved and written.
Content of ‘GeoIP Lookup: *clientip’:
rule "GeoIP lookup: *clientip"
has_field("src_ip")
let geo = lookup("geo-lookup", to_string($message.src_ip));
set_field("src_ip_geolocation", geo["coordinates"]);
set_field("src_ip_geo_country", geo["country"].iso_code);
set_field("src_ip_geo_country_name", geo["country"].names.en);
set_field("src_ip_geo_city", geo["city"].names.en);
After these two rules are executed (I can see there are msg/s triggered on each) there are no messages displayed in my HAProxy stream page.
I know there is a plugin I can enable to get the details, but I seem to have an issue in grafana that the values of the co-ordinates (which are written as ‘lat,long’ and of type string) cannot be correctly interpreted. This statement might be completely wrong, but that is the only reason I could think of that it would not plot the co-ordinates in grafana.
Any help will be greatly appreciated please?
PS: Sorry for the long post, but wanted to give as much info as possible.
