Hi
i am fairly new to graylog , i am looking at setting up alerts for git code changes via graylog
Hello && Welcome
This would depend on your Graylog configuration, log shipper used, ingesting what type of logs.
If you could explain in greater detail that would be great.
Graylog is capable of all types of alert configuration. The most part is what fields are available, Streams created to hold what type of messages and depending the message/log itself. If the logs do not have details you need to identify git code changes then you would have to configure something out that is unique for Identifying these changes.
