Greylog Docker 4.3.9 - Not starting
I had Graylog running awhile back and am now just getting time to get back to it. After creating the docker container again for Graylog, Mongo, and elasticsearch I ran into some issues.
Following the docker setup, the docker crashes. indicating that it can not write to the journal path.
Docker running under Unraid
Package Version: 4.3.9
Environment:
Overview: Official Graylog Docker image.
For more variables see the Graylog configuration file: …
The default root user is named ‘admin’
To create the SHA256 string run ‘echo -n YOUR16CHARACTERPASSWORD | sha256sum’
Additional Requirements:
Repository: graylog/graylog:4.3.9
Docker Hub URL: Docker
Icon URL:
WebUI: http://[IP]:[PORT:9000]
Extra Parameters:
Post Arguments:
CPU Pinning:
Network Type: Host
Console shell command: Shell
Privileged: OFF
GRAYLOG_PASSWORD_SECRET: ••••••••••••••••
Container Variable: GRAYLOG_PASSWORD_SECRET
GRAYLOG_ROOT_PASSWORD_SHA2:
Container Variable: GRAYLOG_ROOT_PASSWORD_SHA2
GRAYLOG_HTTP_EXTERNAL_URI: http://10.71.74.23:9000/
Container Variable: GRAYLOG_HTTP_EXTERNAL_URI
Graylog web interface and REST API: 9000 (Container Port: 9000)
Syslog TCP: 1514 (Container Port: 1514)
Syslog UDP: 1514 (Container Port: 1514)
GELF TCP: 12201 (Container Port: 12201)
GELF UDP: 12201 (Container Port: 12201)
MongoDB connection string: mongodb://10.71.74.23:27017/graylog
Container Variable: GRAYLOG_MONGODB_URI
List of Elasticsearch hosts Graylog should connect to: 10.71.74.23:9200
Container Variable: GRAYLOG_ELASTICSEARCH_HOSTS
Need to be specified as a comma-separated list of valid URIs for the http ports of your elasticsearch nodes
Appdata: /mnt/user/appdata/greylog
Container Path: /usr/share/graylog/data/journal
Last line of Docker log:
“2022-12-27 15:56:07,662 ERROR: org.graylog2.bootstrap.preflight.PreflightCheckService - Preflight
check failed with error: Journal directory </usr/share/graylog/data/journal> is not writable!”
Found that the host path that had been created under appdata, had folder permissions that were set to root only from the docker setup, I adjusted the permissions to “drwxrwxr-x 1 root users 0 Dec 26 19:39 greylog/” and made sure that the users group had this folder.
Has anyone run into this recently, I do not remember having this problem the last time I started to set things up. Since the users group has read/write to the folder I’m not sure where to look at the moment for the underlying cause.
strong text
GL uses a dedicated graylog group with ID 1100. You need to give that write permissions to your journal directory.
