Grayog 100% CPU Usage
Graylog consume 100% CPU all the time and the VM freeze.
Graylog version 6.0.5.1
Java version 17.0.12
The VM has 16 vCPU, 32GB RAM.
I tried to put lower buffers values.
server.conf :
elasticsearch_hosts = http://127.0.0.1:9200
disabled_retention_strategies = none,close
allow_highlighting = false
field_value_suggestion_mode = on
output_batch_size = 500
processbuffer_processors = 2
outputbuffer_processors = 2
ring_size = 65536
inputbuffer_ring_size = 65536
inputbuffer_processors = 1
integrations_scripts_dir = /usr/share/graylog-server/scripts
thx in advance.
Best Regards,
Could this be a Java issue and not using the internal Java that comes with Graylog
How can i check ?
As mentioned in the topic:
Can you try to “comment out” (add a # to the line) this line, JAVA=/usr/bin/java, in your JVM settings file? Should be /etc/sysconfig/graylog-server for RPM/yum installs.
Should look like this when commented out
This will allow graylog to use its bundled JDK and no longer rely on the OS jdk.
And the bottem linu in graylog website shoud state something like:
Graylog 5.2.10+c04b5a4 on (Eclipse Adoptium 17.0.12 on Linux 4.18.0-553.16.1.el8_10.x86_64)
I dont have graylog-server in /etc/sysconfig/ ; Only opensearch.
On the opensearch conf, i don’t have these lines : “JAVA=/user/bin/java”
# k-NN Lib Path
LD_LIBRARY_PATH=$LD_LIBRARY_PATH:/usr/share/opensearch/plugins/opensearch-knn/lib
# OpenSearch Java path
#OPENSEARCH_JAVA_HOME=/usr/lib/jvm/java-11-amazon-corretto
# OpenSearch configuration directory
# Note: this setting will be shared with command-line tools
OPENSEARCH_PATH_CONF=/etc/opensearch
# OpenSearch PID directory
PID_DIR=/var/run/opensearch
# Additional Java OPTS
#OPENSEARCH_JAVA_OPTS=
# Configure restart on package upgrade (true, every other setting will lead to not restarting)
#RESTART_ON_UPGRADE=true
# OpenSearch service
# The number of seconds to wait before checking if OpenSearch started successfully as a daemon process
OPENSEARCH_STARTUP_SLEEP_TIME=5
# Notification for systemd
OPENSEARCH_SD_NOTIFY=true
# System properties
# Specifies the maximum file descriptor number that can be opened by this process
# When using Systemd, this setting is ignored and the LimitNOFILE defined in
# /usr/lib/systemd/system/opensearch.service takes precedence
#MAX_OPEN_FILES=65535
# The maximum number of bytes of memory that may be locked into RAM
# Set to "unlimited" if you use the 'bootstrap.memory_lock: true' option
# in opensearch.yml.
# When using systemd, LimitMEMLOCK must be set in a unit file such as
# /etc/systemd/system/opensearch.service.d/override.conf.
#MAX_LOCKED_MEMORY=unlimited
# Maximum number of VMA (Virtual Memory Areas) a process can own
# When using Systemd, this setting is ignored and the 'vm.max_map_count'
# property is set
You can find the option under /etc/default/graylog-server assuming this is Ubuntu.
the option was commented, I tried to uncomment it but still the same problem
It appears Graylog and Opensearch are installed to the same node, is the host hitting 100% CPU without ingest or are you currently ingesting data. If you are ingesting data, how much per day?
When looking under system/nodes are both the process and output buffer full or just the process buffer?
