High CPU Usage Graylog 3.3.9
Hello!
We have a graylog and it consumes a lot of CPU time. Always 100%.
Graylog version: 3.3.9
Java version: java-1.8.0-openjdk-1.8.0.332.b09-1.el7_9.x86_64
VM has 16 cores and 48 GB RAM
What did you try to do?
  1. Checked the config file of the greylog. On the processor, everything is set correctly, as far as I understand.
  2. Updated Graylog itself to version 4.2 - did not help
  3. Updated Java version for graylog version 3.3.9 - did not help (tried to use version 11)
  4. For version 4.2, I used three different versions of Java - 1.8, 11, 17 - did not help.
  5. Tried inscrese cores from 16 to 40 but nothing.
  6. Disabled inputs - but nothing.
    Could you suggest where else to look?
top -H:
cat /etc/graylog/server/server.conf
is_master = true
password_secret = SECRET
root_username = root
root_password_sha2 = SECRET
root_timezone = Europe/London
rest_listen_uri = 0.0.0.0:9000/api/
rest_transport_uri = IP:9000/api/
trusted_proxies = 127.0.0.1/32, 0:0:0:0:0:0:0:1/128
web_enable = true
web_listen_uri = 0.0.0.0:9000/
elasticsearch_hosts = server01:9200,server02:9200
elasticsearch_max_total_connections = 20
rotation_strategy = count
retention_strategy = delete
elasticsearch_shards = 4
elasticsearch_replicas = 0
allow_highlighting = false
output_batch_size = 1000
output_flush_interval = 1
processbuffer_processors = 12
outputbuffer_processors = 4
processor_wait_strategy = yielding
ring_size = 2097152
inputbuffer_ring_size = 65536
inputbuffer_processors = 2
inputbuffer_wait_strategy = yielding
message_journal_max_age = 72h
message_journal_max_size = 32gb
transport_email_hostname = smtp.domain.com
transport_email_port = 25
transport_email_use_tls = false
transport_email_from_email = SERVER@domain.com
Thanks.
Hello && Welcome @staybox
From the title of this post and comparing it to your setting and resources.
I see that JAVA is not the option in this case.
First, What i see is these settings since were talking about High CPU Usage.
Those combined equal are 18 CPU threads created, It is advisable to increase the amount of CPU cores. For example If you don’t need that many Processor Buffer I would decrease it this would depend on how many messages are being ingested. A ideal setting would be is the combine buffer setting would be less then the amount of CPU cores this device has, You need to insure that a couple CPU cores is left for the OS.
Next, Bad GROK/REGEX extractors or pipelines can be the culprit this will defiantly jack up the CPU usage and/or memory.
And last, Your version of Graylog
Does not match the version of Graylog Configuration file. You need to look at the documentation here.
The Graylog configuration your using is for 2.4 NOT 3.3 or 4.2. you may want to recheck that.
Many thanks for your answer.
We changed this parameters in server.conf file (from yielding to blocking and CPU usage don’t high now.):
I think that changed parameters solved high CPU usage problem.
