Graylog with Nginx Reverse Proxy (Centos 7)
My Setup is as follows:
/etc/nginx/conf.d/example.com.conf
    server {
            listen 80;
            server_name graylog.example.com;
            return 301 https://$server_name$request_uri/api;
    server {
            listen 443;
            server_name graylog.example.com 1.1.1.1;
            ssl on;
            ssl_certificate /etc/letsencrypt/live/graylog.example.com/fullchain.pem;
            ssl_certificate_key /etc/letsencrypt/live/graylog.example.com/privkey.pem;
            access_log /var/www/vhosts/graylog.example.com/access.log;
            error_log /var/www/vhosts/graylog.example.com/error.log;
            location / {
                    proxy_set_header X-Graylog-Server-URL https://$server_name/api;
                    proxy_pass       https://127.0.0.1:9100;
/etc/graylog/server/server.conf
    # GRAYLOG CONFIGURATION FILE
    # This is the Graylog configuration file. The file has to use ISO 8859-1/Latin-1 character encoding.
    # Characters that cannot be directly represented in this encoding can be written using Unicode escapes
    # as defined in https://docs.oracle.com/javase/specs/jls/se8/html/jls-3.html#jls-3.3, using the \u prefix.
    # For example, \u002c.
    # * Entries are generally expected to be a single line of the form, one of the following:
    # propertyName=propertyValue
    # propertyName:propertyValue
    # * White space that appears between the property name and property value is ignored,
    #   so the following are equivalent:
    # name=Stephen
    # name = Stephen
    # * White space at the beginning of the line is also ignored.
    # * Lines that start with the comment characters ! or # are ignored. Blank lines are also ignored.
    # * The property value is generally terminated by the end of the line. White space following the
    #   property value is not ignored, and is treated as part of the property value.
    # * A property value can span several lines if each line is terminated by a backslash (‘\’) character.
    #   For example:
    # targetCities=\
    #         Detroit,\
    #         Chicago,\
    #         Los Angeles
    #   This is equivalent to targetCities=Detroit,Chicago,Los Angeles (white space at the beginning of lines is ignored).
    # * The characters newline, carriage return, and tab can be inserted with characters \n, \r, and \t, respectively.
    # * The backslash character must be escaped as a double backslash. For example:
    # path=c:\\docs\\doc1
    # If you are running more than one instances of Graylog server you have to select one of these
    # instances as master. The master will perform some periodical tasks that non-masters won't perform.
    is_master = true
    # The auto-generated node ID will be stored in this file and read after restarts. It is a good idea
    # to use an absolute file path here if you are starting Graylog server from init scripts or similar.
    # You MUST set a secret to secure/pepper the stored user passwords here. Use at least 64 characters.
    # Generate one by using for example: pwgen -N 1 -s 96
    password_secret = plain text pass
    #root_username = admin
    # You MUST specify a hash password for the root user (which you only need to initially set up the
    # system and in case you lose connectivity to your authentication backend)
    # This password cannot be changed using the API or via the web interface. If you need to change it,
    # modify it in this file.
    # Create one by using for example: echo -n yourpassword | shasum -a 256
    # and put the resulting hash value into the following line
    root_password_sha2 = encrypted pass
    # Default is empty
    root_email = "admin@example.com"
    # Default is UTC
    root_timezone = Europe/London
    # REST API listen URI. Must be reachable by other Graylog server nodes if you run a cluster.
    # When using Graylog Collectors, this URI will be used to receive heartbeat messages and must be accessible for all collectors.
    rest_listen_uri = https://0.0.0.0:9100/api/
    # REST API transport address. Defaults to the value of rest_listen_uri. Exception: If rest_listen_uri
    # is set to a wildcard IP address (0.0.0.0) the first non-loopback IPv4 system address is used.
    # If set, this will be promoted in the cluster discovery APIs, so other nodes may try to connect on
    # this address and it is used to generate URLs addressing entities in the REST API. (see rest_listen_uri)
    # You will need to define this, if your Graylog server is running behind a HTTP proxy that is rewriting
    # the scheme, host name or URI.
    # This must not contain a wildcard address (0.0.0.0).
    rest_transport_uri = https://1.1.1.1:9100/api/
    # Enable CORS headers for REST API. This is necessary for JS-clients accessing the server directly.
    # If these are disabled, modern browsers will not be able to retrieve resources from the server.
    # This is enabled by default. Uncomment the next line to disable it.
    #rest_enable_cors = false
    # Enable GZIP support for REST API. This compresses API responses and therefore helps to reduce
    #rest_enable_gzip = false
    # Enable HTTPS support for the REST API. This secures the communication with the REST API with
    # TLS to prevent request forgery and eavesdropping. This is disabled by default. Uncomment the
    # next line to enable it.
    rest_enable_tls = true
    # The X.509 certificate chain file in PEM format to use for securing the REST API.
    rest_tls_cert_file = /etc/graylog/server/ssl/cert.pem
    # The PKCS#8 private key file in PEM format to use for securing the REST API.
    rest_tls_key_file = /etc/graylog/server/ssl/pkcs8-encrypted.pem
    # The password to unlock the private key used for securing the REST API.
    #rest_tls_key_password = secret
    #rest_max_header_size = 8192
    # The maximal length of the initial HTTP/1.1 line in bytes.
    #rest_max_initial_line_length = 4096
    # The size of the thread pool used exclusively for serving the REST API.
    #rest_thread_pool_size = 16
    # Enable the embedded Graylog web interface.
    # Default: true
    web_enable = true
    # Web interface listen URI.
    # Configuring a path for the URI here effectively prefixes all URIs in the web interface. This is a replacement
    # for the application.context configuration parameter in pre-2.0 versions of the Graylog web interface.
    web_listen_uri = https://0.0.0.0:9100/
    # Web interface endpoint URI. This setting can be overriden on a per-request basis with the X-Graylog-Server-URL header.
    # Default: $rest_transport_uri
    #web_endpoint_uri =
    # Enable CORS headers for the web interface. This is necessary for JS-clients accessing the server directly.
    #web_enable_cors = false
    # Enable/disable GZIP support for the web interface. This compresses HTTP responses and therefore helps to reduce
    #web_enable_gzip = false
    # Enable HTTPS support for the web interface. This secures the communication of the web browser with the web interface
    # using TLS to prevent request forgery and eavesdropping.
    # This is disabled by default. Uncomment the next line to enable it and see the other related configuration settings.
    web_enable_tls = true
    # The X.509 certificate chain file in PEM format to use for securing the web interface.
    web_tls_cert_file = /etc/graylog/server/ssl/cert.pem
    # The PKCS#8 private key file in PEM format to use for securing the web interface.
    web_tls_key_file = /etc/graylog/server/ssl/pkcs8-encrypted.pem
    # The password to unlock the private key used for securing the web interface.
    #web_tls_key_password = secret
    #web_max_header_size = 8192
    #web_max_initial_line_length = 4096
    # The size of the thread pool used exclusively for serving the web interface.
    #web_thread_pool_size = 16
    # requires authentication.
    # Maximum amount of time to wait for successfull connection to Elasticsearch HTTP port.
    # Default: 10 Seconds
    # Default: 60 seconds
    # be tore down.
    # Default: inf
    # Default: 20
    #elasticsearch_max_total_connections = 20
    # elasticsearch server).
    # Default: 2
    #elasticsearch_max_total_connections_per_route = 2
    # Maximum number of times Graylog will retry failed requests to Elasticsearch.
    # Default: 2
    #elasticsearch_max_retries = 2
    # Enable automatic Elasticsearch node discovery through Nodes Info,
    # see https://www.elastic.co/guide/en/elasticsearch/reference/5.4/cluster-nodes-info.html
    # WARNING: Automatic node discovery does not work if Elasticsearch requires authentication, e. g. with Shield.
    # Default: false
    #elasticsearch_discovery_enabled = true
    # Filter for including/excluding Elasticsearch nodes in discovery according to their custom attributes,
    # see https://www.elastic.co/guide/en/elasticsearch/reference/5.4/cluster.html#cluster-nodes
    # Default: empty
    #elasticsearch_discovery_filter = rack:42
    # Default: 30s
    # Default: false
    # Graylog will use multiple indices to store documents in. You can configured the strategy it uses to determine
    # when to rotate the currently active write index.
    # It supports multiple rotation strategies:
    #   - "count" of messages per index, use elasticsearch_max_docs_per_index below to configure
    #   - "size" per index, use elasticsearch_max_size_per_index below to configure
    # valid values are "count", "size" and "time", default is "count"
    rotation_strategy = count
    #  1w  = 1 week
    #  1d  = 1 day
    #  12h = 12 hours
    #no_retention = false
    retention_strategy = delete
    elasticsearch_shards = 4
    elasticsearch_replicas = 0
    # Default: graylog-internal
    # be enabled with care. See also: http://docs.graylog.org/en/2.1/pages/queries.html
    allow_highlighting = false
    # Global request timeout for Elasticsearch requests (e. g. during search, index creation, or index time-range
    # calculations) based on a best-effort to restrict the runtime of Elasticsearch operations.
    # Default: 1m
    #elasticsearch_request_timeout = 1m
    # Default: 1h
    # Default: 20
    # Default: 1h
    output_batch_size = 500
    output_flush_interval = 1
    processbuffer_processors = 5
    outputbuffer_processors = 3
    # Possible types:
    #  - yielding
    #  - sleeping
    #  - blocking
    #  - busy_spinning
    ring_size = 65536
    inputbuffer_ring_size = 65536
    inputbuffer_processors = 2
    # Enable the disk based message journal.
    # The directory which will be used to store the message journal. The directory must me exclusively used by Graylog and
    # ATTENTION:
    # disabled if not set.
    # Length of the interval in seconds in which the alert conditions for all streams should be checked
    # and alarms are being sent.
    #alert_check_interval = 60
    # messages end up.
    #stale_master_timeout = 2000
    #shutdown_timeout = 30000
    # MongoDB connection string
    #mongodb_uri = mongodb://grayloguser:secret@localhost:27017,localhost:27018,localhost:27019/graylog
    # http://api.mongodb.com/java/current/com/mongodb/MongoOptions.html#threadsAllowedToBlockForConnectionMultiplier
    # Drools Rule File (Use to rewrite incoming log messages)
    # See: http://docs.graylog.org/en/2.1/pages/drools.html
    #rules_file = /etc/graylog/server/rules.drl
    # Email transport
    #transport_email_enabled = false
    #transport_email_hostname = mail.example.com
    #transport_email_port = 587
    #transport_email_use_auth = true
    #transport_email_use_ssl = true
    #transport_email_subject_prefix = [graylog]
    # Default: 5s
    #http_connect_timeout = 5s
    # Default: 10s
    #http_read_timeout = 10s
    # Default: 10s
    #http_write_timeout = 10s
    #http_proxy_uri =
    # Disable the optimization of Elasticsearch indices after index cycling. This may take some load from Elasticsearch
    # on heavily used systems with large indices, but it will decrease search performance. The default is to optimize
    # cycled indices.
    #disable_index_optimization = true
    # Optimize the index down to <= index_optimization_max_num_segments. A higher number may take some load from Elasticsearch
    # on heavily used systems with large indices, but it will decrease search performance. The default is 1.
    #index_optimization_max_num_segments = 1
    # The threshold of the garbage collection runs. If GC runs take longer than this threshold, a system notification
    # will be generated to warn the administrator about possible problems with the system. Default is 1 second.
    #gc_warning_threshold = 1s
    # Connection timeout for a configured LDAP server (e. g. ActiveDirectory) in milliseconds.
    # Disable the use of SIGAR for collecting system stats
    #disable_sigar = false
    # The default cache time for dashboard widgets. (Default: 10 seconds, minimum: 1 second)
    # Automatically load content packs in "content_packs_dir" on the first start of Graylog.
    #content_packs_loader_enabled = true
    # The directory which contains content packs which should be loaded on the first start of Graylog.
    # A comma-separated list of content packs (files in "content_packs_dir") which should be applied on
    # the first start of Graylog.
    # Default: empty
    # For some cluster-related REST requests, the node must query all other nodes in the cluster. This is the maximum number
    # of threads available for this. Increase it, if '/cluster/*' requests take long to complete.
    # Should be rest_thread_pool_size * average_cluster_size if you have a high number of concurrent users.
However I get the error 502 Bad Gateway
SELinux is Disabled
I have no firewall enabled currently
Any help would be appreciated.
Check the logs of your nginx.
Fixed it, turns out it was Elasticsearch 6 that was causing the issue. Downgraded to 5 something and that fixed it.
