Graylog will not load
My Graylog (ver 2.4) is attached to LUNs on my netapp. While I was on vacation Graylog lost communication with the drive I have logs written to (not sure why I am not storage) after fixing the storage issue the site will not load. I think something happened to my Mongodb.
root@ubuntu:~# mongod
2019-09-05T07:06:19.647-0700 I CONTROL [initandlisten] MongoDB starting : pid=3453 port=27017 dbpath=/data/db 64-bit host=ubuntu
2019-09-05T07:06:19.647-0700 I CONTROL [initandlisten] db version v3.6.3
2019-09-05T07:06:19.648-0700 I CONTROL [initandlisten] git version: 9586e557d54ef70f9ca4b43c26892cd55257e1a5
2019-09-05T07:06:19.648-0700 I CONTROL [initandlisten] OpenSSL version: OpenSSL 1.0.2g 1 Mar 2016
2019-09-05T07:06:19.648-0700 I CONTROL [initandlisten] allocator: tcmalloc
2019-09-05T07:06:19.648-0700 I CONTROL [initandlisten] modules: none
2019-09-05T07:06:19.648-0700 I CONTROL [initandlisten] build environment:
2019-09-05T07:06:19.648-0700 I CONTROL [initandlisten] distmod: ubuntu1604
2019-09-05T07:06:19.648-0700 I CONTROL [initandlisten] distarch: x86_64
2019-09-05T07:06:19.648-0700 I CONTROL [initandlisten] target_arch: x86_64
2019-09-05T07:06:19.648-0700 I CONTROL [initandlisten] options: {}
2019-09-05T07:06:19.648-0700 I STORAGE [initandlisten] exception in initAndListen: NonExistentPath: Data directory /data/db not found., terminating
2019-09-05T07:06:19.648-0700 I CONTROL [initandlisten] now exiting
2019-09-05T07:06:19.648-0700 I CONTROL [initandlisten] shutting down with code:100
Mongod.log
2019-09-04T15:46:04.085-0700 W - [initandlisten] Detected unclean shutdown - /var/lib/mongodb/mongod.lock is not empty.
2019-09-04T15:54:34.153-0700 E STORAGE [initandlisten] WiredTiger error (0) [1567637674:153267][1356:0x7fc3ce0e29c0], file:collection-67–3864921791193957682.wt, WT_CURSOR.prev: read checksum error for 4096B block at offset 696320: block header checksum of 3556023370 doesn’t match expected checksum of 3809927217
it looks like your mongoDB is wrecked.
Restore from Backup and you are in the game again.
Might want to check your storage is definitely mounted properly and Mongo can access the data?
That is what I was afraid of, thanks
After googling I found if I run mongod --dbpath /var/lib/mongodb/ graylog starts to work. I am running the cmd over ssh. When I close out my ssh Window graylog stops. So (I am assuming) running mongod --dbpath /var/lib/mongodb/ starts the DB??? How do I fix this so I dont have to ssh in to the box and keep running it??
sorry dude - but that is linux basic knowledge I’ll not teach here:
One of the following certificates will give you the knowledge about your problem.
  • LINUX + CompTIA.
  • RHCE- RED HAT CERTIFIED ENGINEER.
  • GCUX: GIAC CERTIFIED UNIX SECURITY ADMINISTRATOR.
  • ORACLE LINUX OCA & OCP.
  • LPI ( LINUX PROFESSIONAL INSTITUTE) CERTIFICATIONS .
Wow, not looking to get a cert dude, just looking to get graylog up and running again. Anyone else care to help me out?
Run MongoDB as a service.
