Graylog unable to collect data from Filebeat
Hello Everyone,
I have installed graylog 4.0 on server-1 and it running successfully. On the other hand, on server-2, I have a website deployed behind an nginx webserver. I want to collect all the logs of this website and send it to graylog on server-1.
  • For this I have installed Filebeat on server-2.
  • Made to changes to filebeat.yml - enabled logs and added ip of graylog(server-1)
Graylog is still not able to collect the logs.
Is there something wrong with my approach or might be a firewall issue?
Hi there,
Can you give us a bit more information? Most useful in this case would be:
  • Your Graylog server’s Input configuration
  • Your filebeat.yml
That should help us get a bit closer to finding out what the issue is.
Sure. PFB the details -
Global Input ss of graylog server -
UFW status for graylog server -
I actually solved it.
The path was not correct in the filebeat inputs section.
Thanks! :slight_smile:
