Graylog TLS to Opensearch instance
I can’t get a proper TLS connection between Graylog and Opensearch to run.
If I check with openssl s_client the connection seems to have no problems at all!
  • OS Information:
OS: SLES 15 SP5 (for both Opensearch and Graylog)
Package Version:
Graylog: graylog-server 5.0.3-1
Opensearch: opensearch 2.5.0-1
graylog logs:
2024-01-26T14:55:40.813+01:00 INFO [VersionProbe] Elasticsearch is not available. Retry #128
2024-01-26T14:55:45.817+01:00 ERROR [VersionProbe] Unable to retrieve version from Elasticsearch node: unexpected end of stream on http://10.252.18.78:9200/… - \n not found: limit=0 content=….
2024-01-26T14:55:45.817+01:00 INFO [VersionProbe] Elasticsearch is not available. Retry #129
2024-01-26T14:55:50.820+01:00 ERROR [VersionProbe] Unable to retrieve version from Elasticsearch node: unexpected end of stream on http://10.252.18.78:9200/… - \n not found: limit=0 content=….
2024-01-26T14:55:50.821+01:00 INFO [VersionProbe] Elasticsearch is not available. Retry #130
opensearch logs:
[2024-01-26T14:56:30,853][ERROR][o.o.s.a.s.InternalOpenSearchSink] [XXX] Unable to index audit log {“audit_node_id”:“irjEwfHSQXKOqPYchU8p7Q”,“audit_request_layer”:“REST”,“audit_request_exception_stackt
race”:"io.netty.handler.ssl.NotSslRecordException: not an SSL/TLS record:
Config Opensearch
discovery.type: single-node
path.data: /var/lib/opensearch
network.host: xxx.xxx.xxx.xxx
http.port: 9200
plugins.security.disabled: false
plugins.security.ssl.transport.pemcert_filepath: xxx.y.z.crt.pem #esnode.pem
plugins.security.ssl.transport.pemkey_filepath: xxx.y.z.key.pem #esnode-key.pem
plugins.security.ssl.transport.pemtrustedcas_filepath: my-ca.pem #root-ca.pem
plugins.security.ssl.transport.enforce_hostname_verification: false
plugins.security.ssl.http.enabled: true
plugins.security.ssl.http.pemcert_filepath:xxx.crt.pem #esnode.pem
plugins.security.ssl.http.pemkey_filepath: xxx.key.pem # esnode-key.pem
plugins.security.ssl.http.pemtrustedcas_filepath: my-ca.pem #root-ca.pem
plugins.security.allow_unsafe_democertificates: true
plugins.security.allow_default_init_securityindex: true
plugins.security.authcz.admin_dn:
  • CN=kirk,OU=client,O=client,L=test, C=de
plugins.security.audit.type: internal_opensearch
plugins.security.enable_snapshot_restore_privilege: true
plugins.security.check_snapshot_restore_write_privileges: true
plugins.security.restapi.roles_enabled: [“all_access”, “security_rest_api_access”]
plugins.security.system_indices.enabled: true
plugins.security.system_indices.indices: [“.plugins-ml-model”, “.plugins-ml-task”, “.opendistro-alerting-config”, “.opendistro-alerting-alert*”, “.opendistro-anomaly-results*”, “.opendistro-anomaly-detector*”, “.opendistro-anomaly-checkpoints”, “.opendistro-anomaly-detection-state”, “.opendistro-reports-", ".opensearch-notifications-”, “.opensearch-notebooks”, “.opensearch-observability”, “.opendistro-asynchronous-search-response*”, “.replication-metadata-store”]
node.max_local_storage_nodes: 3
config graylog
is_leader = true
password_secret = xxx
root_password_sha2 = xxx
root_timezone = Etc/GMT-1
http_bind_address = xxx.y.z:9000
http_enable_tls = true
http_tls_cert_file = /etc/ssl/private/xxx.y.z.crt.pem
http_tls_key_file = /etc/ssl/private/xxx.y.z.key.pem
elasticsearch_hosts = xxx.xxx.xxx.xxx:9200
rotation_strategy = count
elasticsearch_disable_version_check = true
retention_strategy = delete
elasticsearch_shards = 4
elasticsearch_replicas = 0
allow_highlighting = false
output_batch_size = 500
output_flush_interval = 1
processbuffer_processors = 5
outputbuffer_processors = 3
ring_size = 65536
inputbuffer_ring_size = 65536
inputbuffer_processors = 2
I’ve ensured everything works fine without SSL enabled and then just added a proper certificate and CA file to the opensearch.yml file and also added the CA file to the jks that Graylog uses. Additionally I added the a certificate + key for Graylog to the truststore, in case that was a problem.
Note that the Logs that are sent to graylog are encrypted properly and there are no problems regarding that. The only unencrypted communication happens between Graylog and Opensearch.
The Graylog webinterface itself also flawlessly works via HTTPS.
The install recommendation being add “plugins.security.disabled: false”
to the opensearch configuration does not actually mean that it’s not possible to use the plugin to enable TLS, right?
I kept overlooking that I never changed this setting:
elasticsearch_hosts = http://…:9200
now when I switched it to https:// I can confirm that it validates the host correctly by comparing using IP vs DNS name. But I still get an error that I struggle to decipher properly:
Unable to retrieve version from Elasticsearch node opensearch-server:9200: unknown error - an exception occurred while deserializing error response: com.fasterxml.jackson.core.JsonParseException: Unrecognized token ‘Unauthorized’: was expecting (JSON String, Number, Array, Object or token ‘null’, ‘true’ or ‘false’)
Do I have to adjust anything with the roles now that the security plugin is enabled or how do I deal with this apparent mismatch of json format?
seems to work now, not sure if i changed anything else than elasticsearch_host = https://username:password@opensearch_host:9200
Indeed to get Graylog working with OpenSearch in TLS the right format is https://user:password@host:9200
