Graylog System Events index not respecting Field Type Refresh Interval setting
I recently changed our AWS OpenSearch to use or2 instance type. These require a minimum 10s refresh interval on indexes. I have updated all the “Field Type Refresh Interval” settings to respect this. However, the “Graylog System Events“ index is not respecting it’s setting of “60s”
  • OS Information: Rocky 9/Docker
  • Package Version: Graylog 6.3.2+667aca0
	Suppressed: org.graylog.shaded.opensearch2.org.opensearch.client.ResponseException: method [PUT], host [https://*****.es.amazonaws.com], URI [/_template/gl-system-events-template?master_timeout=30s], status line [HTTP/1.1 400 Bad Request]
{"error":{"root_cause":[{"type":"illegal_argument_exception","reason":"invalid index.refresh_interval [1s]: cannot be smaller than cluster.minimum.index.refresh_interval [10s]"}],"type":"illegal_argument_exception","reason":"invalid index.refresh_interval [1s]: cannot be smaller than cluster.minimum.index.refresh_interval [10s]"},"status":400}
  • Manually updated the existing indices and template in OS. Graylog always just writes all the settings to the template anyway
  • Had a quick look through the graylog code to see if this is hard-coded somewhere. Didn’t find anything.
  • I have several other indexes which are rotating correctly and using the respective refresh interval in its settings.
I found this issue on GitHub - Make Elastic indices "refresh_interval" setting configurable - or at least with a sensible default · Issue #7800 · Graylog2/graylog2-server · GitHub
The 1s interval is hard-coded in graylog. I shall close this post and attempt to find a solution on the GitHub issue.
