Graylog Sidecar not sending data
Description of your problem
Graylog is not receiving Windows Event Logs from Graylog Sidecar.
Description of steps you’ve taken to attempt to solve the issue
  • Sidecar is running as service, restarted
  • Graylog shows “Running” on Sidecars Overview
  • Cleared all Windows logs on endpoint (new log entries are there)
  • Sidecar configtest shows “Config OK”
  • Sidecar log:
time="2021-10-06T18:21:17+02:00" level=info msg="Stopping signal distributor"
time="2021-10-06T18:21:17+02:00" level=info msg="Starting signal distributor"
time="2021-10-06T18:21:27+02:00" level=info msg="No configurations assigned to this instance. Skipping configuration request.
Environmental information
  • Graylog 4.0.5+d95b909 on ubuntu_1804
  • Graylog Collector Sidecar version 1.0.2 (4a6d445) [go1.11.13/amd64]
Operating system information
  • Ubuntu 18.04
Package versions
  • Graylog: 4.0.5+d95b909, codename Noir
  • MongoDB: v4.0.22
  • Elasticsearch: 7.11.2
  • Service logs, configuration, and environment variables
  • See the docs site for all file locations
Thanks for hints/help
Looks like you haven’t assigned a configuration to the windows machine
Here is the step-by-step guide for sidecar which includes how to assign the configuration.
More specifically it looks like this below… though in this case they are assigning a filebeat config to a linux machine. Once you assign it in the Graylog GUI, Graylog will push the configuration to the Windows machine and the service will restart.
On a side note, Elasticsearch is supposed to stay at 7.10 for now ( you are at 7.11.2) You may want to pin it at that version so it doesn’t’ get too far away from you/guidelines.
Thanks, got it working now. I had to stop Graylog for about 3 weeks.
Somehow that config assignment got lost. I think this should not happen.
