Hi all!
After updating Graylog to version 3.0.2 I got problems with Sidecar + Nxlog combination. Exec blocks does not work anymore ![]()
There is a simple example from Sidecar nxlog on Windows:
<Exec> # These fields are needed for Graylog $gl2_source_collector = '${sidecar.nodeId}'; $collector_node_id = '${sidecar.nodeName}'; </Exec>
I’m sure this code worked before updating Graylog.
Error text:
2019-07-08 18:14:28 ERROR Couldn't parse Exec block at C:\Program Files\Graylog\sidecar\generated\nxlog.conf:41; couldn't parse statement at line 42, character 33 in C:\Program Files\Graylog\sidecar\generated\nxlog.conf; invalid character: ';' (0xd)
Is it possible that the problem is in the generated file nxlog.conf from C:\Program Files\Graylog\sidecar\generated directory? I see extra empty lines in this file… maybe its encoding issue.
(pic from Notepad++)
What am I doing wrong?
P.S. The following code also stopped working when I updated the Sidecar nxlog collector configuration:
Query <QueryList> \ <Query Id="0" Path="DNS Server"> \ <Select Path="DNS Server"> \ *[System[(Level=1 or Level=2 or Level=3)]] \ </Select> \ </Query> \ </QueryList>
