Graylog SaltStack Formula
View on Github
Open Issues
Stargazers
A saltstack formula that can be used to manage graylog installations on RHEL and Debian based systems using a package or tar file.
Table of Contents
- General notes
- Requirements
- Releases
General notes
Note
The FORMULA file, contains information about this formula, tested OS and OS families, and the minimum tested version of salt.
See the full Salt Formulas installation and usage instructions.
You must be running elasticsearch and mongodb to use Graylog.
Formulas exist to help with installation and management of the necessary Graylog stack components, which are; a firewall, elasticsearch, and mongodb at a bare minimum.
firewall-formula GitHub - alias454/firewall-formula: Salt formula to handle firewalld or iptables basic firewall functionality
elasticsearch-formula GitHub - alias454/elasticsearch-formula: Salt formula to install Elasticsearch on RHEL or Debian based systems
mongodb-formula GitHub - alias454/mongodb-formula: Salt formula to install MongoDB on RHEL or Debian based distros
If using mongo authentication, configure a DB in mongo first. Requires the mongodb-formula to include correct mongodb states or one can manually created the appropriate database and user.
Releases
View prior releases Releases · alias454/graylog-formula · GitHub
