I need to define a time frame each month in the alarm configuration, for example the number of messages from 1st of month to 18th of month must be greater than 10000.
Therefore, I want to be able to use this criteria in Natty language : “1st last month to 18th last month” in the query string of an alarm (using Conditional Counting Alert Condition Plugin).
So I first tried to use Natty language in the query fields in the search page, but it didn’t work.
Is it impossible ? Or am I writing the query string incorrectly ?
I tried those queries, but they’re not working :
timestamp:“1st this month to 18th this month”
timestamp:[“1st this month” TO “18th this month”]
It is strange, because those searches are working :
“1st last month to 18th last month” as a keyword
timestamp:[“2018-09-01 00:00:00.000” TO “2018-09-18 00:00:00.000”] in the query field
I got those errors displayed in the search screen during my tests:
Error Message:
Unable to perform search query failed to parse date field [1st this month] with format [yyyy-MM-dd HH:mm:ss.SSS]failed to parse date field [1st this month] with format [yyyy-MM-dd HH:mm:ss.SSS]
Details:
and
Error Message:
Unable to perform search query failed to parse date field [1st this month to 18 this month] with format [yyyy-MM-dd HH:mm:ss.SSS]failed to parse date field [1st this month to 18 this month] with format [yyyy-MM-dd HH:mm:ss.SSS]
Details:
I’m using Graylog 2.4.6.
