dont get it why i cant build the integration plugin
i have modified the template in the paloalto plugin so it works with version 9.1 and also added Globalprotect.
INFO] Scanning for projects…
[WARNING]
[WARNING] Some problems were encountered while building the effective model for org.graylog.plugins:graylog-plugin-integrations:jar:3.2.4
[WARNING] ‘dependencies.dependency.(groupId:artifactId:type:classifier)’ must be unique: io.pkts:pkts-core:jar -> duplicate declaration of version 3.0.5 @ line 136, column 21
[WARNING]
[WARNING] It is highly recommended to fix these problems because they threaten the stability of your build.
[WARNING]
[WARNING] For this reason, future Maven versions might no longer support building such malformed projects.
[WARNING]
[INFO]
[INFO] ----------< org.graylog.plugins:graylog-plugin-integrations >-----------
[INFO] Building graylog-plugin-integrations 3.2.4
[INFO] --------------------------------[ jar ]---------------------------------
[INFO]
[INFO] — frontend-maven-plugin:1.8.0:install-node-and-yarn (install node and yarn) @ graylog-plugin-integrations —
[INFO] Node v12.13.1 is already installed.
[INFO] Yarn 1.19.2 is already installed.
[INFO]
[INFO] — frontend-maven-plugin:1.8.0:yarn (yarn install) @ graylog-plugin-integrations —
[INFO] yarn not inheriting proxy config from Maven
[INFO] Running ‘yarn install’ in /home/larssand/Downloads/graylog/graylog-plugin-integrations
[INFO] yarn install v1.19.2
[INFO] [1/4] Resolving packages…
[INFO] success Already up-to-date.
[INFO] Done in 0.25s.
[INFO]
[INFO] — frontend-maven-plugin:1.8.0:yarn (yarn run build) @ graylog-plugin-integrations —
[INFO] Running ‘yarn run build’ in /home/larssand/Downloads/graylog/graylog-plugin-integrations
[INFO] yarn run v1.19.2
[INFO] $ webpack --bail
[INFO] Running in production mode
[INFO] Hash: 9ec463eef3b47da2f305
[INFO] Version: webpack 3.12.0
[INFO] Time: 1420ms
[INFO] Asset Size Chunks Chunk Names
[INFO] plugin.org.graylog.integrations.IntegrationsPlugin.9ec463eef3b47da2f305.js 63 kB 0 [emitted] plugin.org.graylog.integrations.IntegrationsPlugin
[INFO] plugin.org.graylog.integrations.IntegrationsPlugin.9ec463eef3b47da2f305.js.map 367 kB 0 [emitted] plugin.org.graylog.integrations.IntegrationsPlugin
[INFO] favicon.png 436 bytes [emitted]
[INFO] index.html 410 bytes [emitted]
[INFO] module.json 285 bytes [emitted]
[INFO] plugin.org.graylog.integrations.IntegrationsPlugin.module.json 285 bytes [emitted]
[INFO] [1] delegated ./node_modules/prop-types/index.js from dll-reference __vendor 42 bytes {0} [built]
[INFO] [2] delegated ./node_modules/react/react.js from dll-reference __vendor 42 bytes {0} [built]
[INFO] [7] ./src/web/aws/common/Routes.js 1.37 kB {0} [built]
[INFO] [13] ./src/web/index.jsx 1.01 kB {0} [built]
[INFO] [14] …/graylog2-server/graylog2-web-interface/src/webpack-entry.js 703 bytes {0} [built]
[INFO] [18] …/graylog2-server/graylog2-web-interface/src/util/AppConfig.js 744 bytes {0} [built]
[INFO] [22] ./src/web/aws/AWSInputConfiguration.jsx 856 bytes {0} [built]
[INFO] [23] …/graylog2-server/graylog2-web-interface/src/util/History.js 284 bytes {0} [built]
[INFO] [37] ./src/web/aws/cloudwatch/CloudWatchApp.jsx 2.24 kB {0} [built]
[INFO] [41] ./src/web/aws/context/Sidebar.jsx 337 bytes {0} [built] [failed] [1 error]
[INFO] [42] ./src/web/aws/context/FormData.jsx 2.77 kB {0} [built]
[INFO] [43] ./src/web/aws/context/Steps.jsx 2.76 kB {0} [built]
[INFO] [44] ./src/web/aws/context/Api.jsx 3.23 kB {0} [built]
[INFO] [45] ./src/web/aws/context/AdvancedOptions.jsx 2.21 kB {0} [built]
[INFO] [48] ./package.json 495 bytes {0} [built]
[INFO] + 34 hidden modules
[INFO]
[INFO] ERROR in ./src/web/aws/cloudwatch/CloudWatch.jsx
[INFO] Module build failed: SyntaxError: Unexpected token (113:5)
[INFO]
[INFO] 111 |
[INFO] 112 | return (
[INFO] > 113 | <>
[INFO] | ^
[INFO] 114 | {dirty && !lastStep && }
[INFO] 115 | <Wizard steps={wizardSteps}
[INFO] 116 | activeStep={currentStep}
[INFO]
[INFO] @ ./src/web/aws/cloudwatch/CloudWatchApp.jsx 29:18-41
[INFO] @ ./src/web/index.jsx
[INFO]
[INFO] ERROR in ./src/web/aws/context/Sidebar.jsx
[INFO] Module build failed: SyntaxError: Unexpected token (7:42)
[INFO]
[INFO] 5 |
[INFO] 6 | export const SidebarProvider = ({ children }) => {
[INFO] > 7 | const [sidebar, setSidebar] = useState(<></>);
[INFO] | ^
[INFO] 8 |
[INFO] 9 | const clearSidebar = () => {
[INFO] 10 | setSidebar(<></>);
[INFO]
[INFO] @ ./src/web/aws/cloudwatch/CloudWatchApp.jsx 19:15-45
[INFO] Child html-webpack-plugin for “index.html”:
[INFO] 1 asset
[INFO] [0] …/graylog2-server/graylog2-web-interface/node_modules/html-webpack-plugin/lib/loader.js!../graylog2-server/graylog2-web-interface/templates/index.html.template 1.71 kB {0} [built]
[INFO] [2] (webpack)/buildin/global.js 509 bytes {0} [built]
[INFO] [3] (webpack)/buildin/module.js 517 bytes {0} [built]
[INFO] + 1 hidden module
[INFO] Child html-webpack-plugin for “module.json”:
[INFO] 1 asset
[INFO] [0] …/graylog2-server/graylog2-web-interface/node_modules/html-webpack-plugin/lib/loader.js!../graylog2-server/graylog2-web-interface/templates/module.json.template 541 bytes {0} [built]
[INFO] Child html-webpack-plugin for “plugin.org.graylog.integrations.IntegrationsPlugin.module.json”:
[INFO] 1 asset
[INFO] [0] ./node_modules/html-webpack-plugin/lib/loader.js!../graylog2-server/graylog2-web-interface/templates/module.json.template 575 bytes {0} [built]
[INFO] error Command failed with exit code 2.
[INFO] error Command failed with exit code 2.info Visit https://yarnpkg.com/en/docs/cli/run for documentation about this command.
[INFO] ------------------------------------------------------------------------
[INFO] BUILD FAILURE
[INFO] Total time: 3.734 s
[INFO] Finished at: 2020-04-30T16:32:28+02:00
[ERROR] Failed to execute goal com.github.eirslett:frontend-maven-plugin:1.8.0:yarn (yarn run build) on project graylog-plugin-integrations: Failed to run task: ‘yarn run build’ failed. org.apache.commons.exec.ExecuteException: Process exited with an error: 2 (Exit value: 2) -> [Help 1]
[ERROR]
[ERROR] To see the full stack trace of the errors, re-run Maven with the -e switch.
[ERROR] Re-run Maven using the -X switch to enable full debug logging.
[ERROR]
[ERROR] For more information about the errors and possible solutions, please read the following articles:
[ERROR] [Help 1] http://cwiki.apache.org/confluence/display/MAVEN/MojoFailureException
