Graylog Output to Logstash using TCP+TLS
Hi All,
I am trying to output logs from Graylog to Logstash.
I have configured the Output settings (GELF) for Graylog from GUI as below -
my logstash.pem file has cert and key both added.
On the logstash side I have configured the input file with the cert and key.
I am not able to see logs on the logstash when I configure the TCP+TLS output from Graylog. Do I need to make any more configs on the Graylog ? is any modification needed in graylog.conf ?
Please advice.
Thanks.
Do you have a stream tied to that output? Also, I would suggest you get it working without TLS and then lock it down. Too many variables if you start with TLS.
