Hello Graylog Community !
I can’t install Graylog on Raspberry PI 4B ! (with ubuntu 16.04 LTS, elasticsearch & mongoDB)
I’m trying since 3 weeks, but this time i really need your help.
Could someone add me on discord and helps me to get this working ?
In a virtual machine or amd64 processor, i need 10/15 min to make it running properly in a fresh installation but with a raspberry pi, i give up i tried a lot of things but i really need to make it working on this !
And what’s your problem please describe? Do you have elastic and mongo up and running on raspberry? Do you have only graylog up and running. Please post error messages in log and more informations. Does your raspberry pi have enough RAM, at least 4GB, better 8GB?
I’ll second @shoothub’s post. I’m also curious about the discord invite. Graylog doesn’t use Discord as a means of providing community support.
I run elasticsearch v7.7 without problem, mongodb is running too without problem.
My Raspberry PI has 8 GB of RAM
When i go into the logs of the graylog server i have this :
2021-05-10 14:29:35,854 ERROR: org.graylog2.periodical.IndexerClusterCheckerThread - Uncaught exception in periodical
org.graylog.shaded.elasticsearch7.org.elasticsearch.ElasticsearchException: An error occurred:
at org.graylog.storage.elasticsearch7.ElasticsearchClient.exceptionFrom(ElasticsearchClient.java:136) ~[?:?]
at org.graylog.storage.elasticsearch7.ElasticsearchClient.execute(ElasticsearchClient.java:99) ~[?:?]
at org.graylog.storage.elasticsearch7.ElasticsearchClient.execute(ElasticsearchClient.java:92) ~[?:?]
at org.graylog.storage.elasticsearch7.ClusterAdapterES7.indicesExist(ClusterAdapterES7.java:290) ~[?:?]
at org.graylog.storage.elasticsearch7.ClusterAdapterES7.clusterHealth(ClusterAdapterES7.java:269) ~[?:?]
at org.graylog.storage.elasticsearch7.ClusterAdapterES7.health(ClusterAdapterES7.java:82) ~[?:?]
at org.graylog2.indexer.cluster.Cluster.health(Cluster.java:70) ~[graylog.jar:?]
at org.graylog2.periodical.IndexerClusterCheckerThread.doRun(IndexerClusterCheckerThread.java:58) ~[graylog.jar:?]
at java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:511) [?:1.8.0_292]
at java.util.concurrent.FutureTask.runAndReset(FutureTask.java:308) [?:1.8.0_292]
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.access$301(ScheduledThreadPoolExecutor.java:180) [?:1.8.0_292]
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.run(ScheduledThreadPoolExecutor.java:294) [?:1.8.0_292]
at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1149) [?:1.8.0_292]
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:624) [?:1.8.0_292]
at java.lang.Thread.run(Thread.java:748) [?:1.8.0_292]
Caused by: java.net.ConnectException: Connection refused
at org.graylog.shaded.elasticsearch7.org.elasticsearch.client.RestClient.extractAndWrapCause(RestClient.java:849) ~[?:?]
at org.graylog.shaded.elasticsearch7.org.elasticsearch.client.RestClient.performRequest(RestClient.java:259) ~[?:?]
at org.graylog.shaded.elasticsearch7.org.elasticsearch.client.RestClient.performRequest(RestClient.java:246) ~[?:?]
at org.graylog.shaded.elasticsearch7.org.elasticsearch.client.RestHighLevelClient.internalPerformRequest(RestHighLevelClient.java:1613) ~[?:?]
at org.graylog.shaded.elasticsearch7.org.elasticsearch.client.RestHighLevelClient.performRequest(RestHighLevelClient.java:1598) ~[?:?]
at org.graylog.shaded.elasticsearch7.org.elasticsearch.client.IndicesClient.exists(IndicesClient.java:974) ~[?:?]
at org.graylog.storage.elasticsearch7.ClusterAdapterES7.lambda$indicesExist$13(ClusterAdapterES7.java:290) ~[?:?]
at org.graylog.storage.elasticsearch7.ElasticsearchClient.execute(ElasticsearchClient.java:97) ~[?:?]
… 14 more
at sun.nio.ch.SocketChannelImpl.checkConnect(Native Method) ~[?:1.8.0_292]
at sun.nio.ch.SocketChannelImpl.finishConnect(SocketChannelImpl.java:716) ~[?:1.8.0_292]
at org.graylog.shaded.elasticsearch7.org.apache.http.impl.nio.reactor.DefaultConnectingIOReactor.processEvent(DefaultConnectingIOReactor.java:174) ~[?:?]
at org.graylog.shaded.elasticsearch7.org.apache.http.impl.nio.reactor.DefaultConnectingIOReactor.processEvents(DefaultConnectingIOReactor.java:148) ~[?:?]
at org.graylog.shaded.elasticsearch7.org.apache.http.impl.nio.reactor.AbstractMultiworkerIOReactor.execute(AbstractMultiworkerIOReactor.java:351) ~[?:?]
at org.graylog.shaded.elasticsearch7.org.apache.http.impl.nio.conn.PoolingNHttpClientConnectionManager.execute(PoolingNHttpClientConnectionManager.java:221) ~[?:?]
at org.graylog.shaded.elasticsearch7.org.apache.http.impl.nio.client.CloseableHttpAsyncClientBase$1.run(CloseableHttpAsyncClientBase.java:64) ~[?:?]
… 1 more
2021-05-10 14:29:35,884 ERROR: org.graylog2.periodical.IndexRotationThread - Uncaught exception in periodical
at org.graylog.storage.elasticsearch7.ClusterAdapterES7.isConnected(ClusterAdapterES7.java:162) ~[?:?]
at org.graylog2.indexer.cluster.Cluster.isConnected(Cluster.java:115) ~[graylog.jar:?]
at org.graylog2.periodical.IndexRotationThread.doRun(IndexRotationThread.java:72) ~[graylog.jar:?]
at org.graylog.shaded.elasticsearch7.org.elasticsearch.client.RestHighLevelClient.performRequest(RestHighLevelClient.java:1583) ~[?:?]
at org.graylog.shaded.elasticsearch7.org.elasticsearch.client.RestHighLevelClient.performRequestAndParseEntity(RestHighLevelClient.java:1553) ~[?:?]
at org.graylog.shaded.elasticsearch7.org.elasticsearch.client.ClusterClient.health(ClusterClient.java:130) ~[?:?]
at org.graylog.storage.elasticsearch7.ClusterAdapterES7.lambda$isConnected$9(ClusterAdapterES7.java:162) ~[?:?]
… 12 more
… 1 more
2021-05-10 14:29:45,889 ERROR: org.graylog2.periodical.IndexRotationThread - Uncaught exception in periodical
… 12 more
… 1 more
In my opinion, i prefer using discord because i can get help at the moment, and it’s more usefull in my case because i don’t have a lot of time for making this solution running!
^ That would indicate to me that Graylog can’t connect to Elasticsearch. I’ll point you to the FAQ’s and note that you should always include the following:
Details you should always include
- Which documentation source did you use (URL, short quote).
- Distribution name and its version (
/etc/os-releaseor/etc/*-releaseor/etc/*-version) of any involved host.- Software versions (
<applicationname> --versionorweb application - About).- Additional dependencies (
php -v,ruby -v,python -V, etc.).- Installation method and download source (packages, or source, and if Git,
git show -1).Examples:
yum info graylog-server apt-cache showpkg graylog-server zypper info graylog-serverSteps to reproduce or understand the question
- Configuration files you’ve edited (their content formatted with code tags, their location on disk).
- Cluster and HA related configuration details.
- Order of things, e.g. notification was triggered, corresponding debug log entries, your analysis.
- Which steps are needed to reproduce the problem standalone in a local environment, e.g. Docker or a (Vagrant) VM?
Tip
Keep your private details safe. Remove passwords, credentials, etc. and obfuscate host names from your company environment.
It’s difficult to help solve an issue when the community has no idea how you’ve configured any of your Graylog components.
As for discord, that’s fine, but that isn’t where community support is provided. Remember, this is a community where folks help as they have time–most, if not all here, have full time jobs outside of replying and volunteering their time to help answer questions.
I tried to change the IP of the elasticsearch host instead of 127.0.0.1:9200 and now it’s working well thank you very much !
The only thing i need now is to make Graylog & Elasticsearch working as service (cause i always have to go to the repertory BIN of each one, and launch with : ./elasticsearch -d and ./graylogctl start ).
I want to make them running as daemon automatically each time my raspberry is restarting.
Do you have the line commands to make it working well maybe?
So if you’re using Raspbian or any other OS that’s using systemd as it’s process manager, you’d have to write a systemd unit file. But as I’m saying that, you should need to write any unit files since the standard .deb package includes the unit file. Have you tried running systemctl enable graylog-server --now or systemctl enable elasticsearch-oss --now at all? That should set both of those services to start persistently.
