Graylog not receiving messages on raw or 514
I have just installed Graylog Open and I am not seeing any messages show up on the server from external devices. However, if I send a message from the server itself (i.e., logger --udp --port 514 -n idr1.mdc.com "whatever") it shows up. If I do the same from e.g., IDR2 to IDR1 it does not show up. This holds true for any external device not originating from the local server.
Doing a tcpdump shows the server is receiving logs, but it is not passing them to Graylog.
[me@MDCIDR1 ~]$ sudo tcpdump -i any udp port 514
tcpdump: data link type LINUX_SLL2
dropped privs to tcpdump
tcpdump: verbose output suppressed, use -v[v]... for full protocol decode
listening on any, link-type LINUX_SLL2 (Linux cooked v2), snapshot length 262144 bytes
20:58:50.264598 eth0  In  IP mdcwifi.wlc.mdc.com.32844 > idr1.mdc.com.syslog: SYSLOG local0.warning, length: 178
20:58:50.264599 eth0  In  IP mdcwifi.wlc.mdc.com.32844 > idr1.mdc.com.syslog: SYSLOG local0.notice, length: 145
20:58:54.552717 eth0  In  IP mdcwifi.wlc.mdc.com.32844 > idr1.mdc.com.syslog: SYSLOG local0.warning, length: 178
Interestingly it seems like the server is only listening on IPv6? Or am I interpreting this wrong/it doesn’t mean anything?
[me@MDCIDR1 ~]$ sudo netstat -tulnp | grep :514
udp6       0      0 10.20.10.4:514          :::*                                1095/java
  • OS Information: RHEL 9.5
  • Package Version: Graylog 6.1.5-2
  • IDR1 - Raw UDP
    bind_address: 10.20.10.4
    charset_name: UTF-8
    number_worker_threads: 2
    override_source:
    port: 5555
    recv_buffer_size: 262144
  • IDR1 - Syslog - UDP
    allow_override_date: true
    charset_name: UTF-8
    expand_structured_data: false
    force_rdns: false
    override_source:
    port: 514
    store_full_message: true
    timezone: America/Chicago
  • Sending from multiple devices… PA-850, WLC 3504, 2930M…
  • Confirmed traffic is allowed by external firewall (and I assume must be allowed by the server firewall since it appears in tcpdump)
  • Confirmed traffic shows up on the server in a packet capture
  • Confirmed traffic shows up fine when pointed to SolarWinds Kiwi Syslog Server
  • Attempted doing raw inputs on 5555
  • What are some next steps I can take to troubleshoot this further? Linux, Graylog, the database thing, they are not something I am familiar with in the slightest.
  • I have the node, and the server, configured on the same VM for staging. Would separating the node and server specifically help with this issue?
What is the binding set to in server.conf, I think i have seen cases where it wound up bound to only ipv6 because of some weird Linux stuff.
You could also just try and disable ipv6 if thats an option, it may work.
It’s just the default - http_bind_address = 0.0.0.0:9000
Actually, it turns out I am just an idiot. I discounted the RHEL firewall because stuff showed up in tcpdump, but after deciding it couldn’t hurt and adding an inbound rule for UDP/514 messages are now showing up.
Sorry about that. Thanks for the help.
