as I didn’t found any info on possible topologies of a multi-node setup i ask it here.
Is it possible to do a multi-node setup with a star topology? So that only the master node sees all other nodes. And the nodes work on there own, and process the logs alone?
Or do I have to have a meshed topology for all nodes?
The Nodes should only work as aggregator + some pipeline magic for multiple beats to output to an ES-Cloud instance. So no searching on this “Edge”-nodes.
thx
