Hi All,
I agreed to configure the graylog to monitor my vsftp server.
It is working perfectly, but I doubt if I can configure Graylog as follows for my FTP clients.
I need to create some accesses on Garylog for my clients to see only their ftp users’ log lines.
I saw that I can make filters and display only one specific user.
But I don’t know if it is possible to create an access for a client and leave this search fixed so that he does not see the logs of other clients.
Follow my log /var/log/vsftp.log
shoothub
(Shoothub)
2
You can create stream for every client and allow client to access to specific stream.
https://docs.graylog.org/en/4.0/pages/streams.html
Thank you, shoothub
I will study the documentation.
Hi, shoothub
I did the index set configuration and then added the stream but it doesn’t display anything.
What do we need to do?
Thank you
I managed to create the role in the streams with regex.Pattern
Thank you anyway!
system
(system)
Closed
6
