some background on the setup:
- Graylog 3.3.2 with installed metrics-reporter-gelf plugin (version 3.0.0)
- Plugin output is configured to send data as GELF to localhost on port 10001
- Graylog is configured with a corresponding GELF TCP input
- Messages are not modified except being routed to a stream and in a separate index set (short retention)
Most of it is working fine, and we can query the metrics.
With every push of new metrics we see a few “Failed to index message” warnings:
2020-07-14T17:45:13.131+02:00 WARN [Messages] Failed to index message: index=<graylog_metrics_13> id=<015f5c27-c5e9-11ea-af20-005056904875> error=<{"type":"mapper_parsing_exception","reason":"failed to parse field [value] of type [long] in document with id '015f5c27-c5e9-11ea-af20-005056904875'","caused_by":{"type":"illegal_argument_exception","reason":"For input string: \"Tue Jul 14 17:43:52 CEST 2020\""}}>
2020-07-14T17:45:13.131+02:00 WARN [Messages] Failed to index message: index=<graylog_metrics_13> id=<015c7606-c5e9-11ea-af20-005056904875> error=<{"type":"mapper_parsing_exception","reason":"failed to parse field [value] of type [long] in document with id '015c7606-c5e9-11ea-af20-005056904875'","caused_by":{"type":"illegal_argument_exception","reason":"For input string: \"[]\""}}>
I am a bit at a loss as I can not figure out the cause for those warnings.
The mismatch of type long with the content shown in the warning is to be expected, but I can not find the data of the wrong type anywhere in the data that is being sent to Graylog.
I sniffed the GELF traffic and can not find a field called value with a timestamp.
Some excerpt from the traffic I saw:
"version": "1.1",
"timestamp": 1.59474118289E9,
"host": "metrics",
"short_message": "name=org.graylog2.shared.buffers.ProcessBuffer.decodeTime type=TIMER",
"level": 6,
"_mean_rate": 493.79032918602144,
"_m1": 449.8989474964472,
"_max": 23.452638,
"_count": 1105029,
"_m5": 467.7861161082778,
"_rate_unit": "second",
"_type": "TIMER",
"_p95": 0.543602,
"_duration_unit": "milliseconds",
"_p98": 0.650645,
"_p75": 0.426937,
"_m15": 441.9039458482535,
"_p99": 0.795899,
"_min": 0.017183,
"_median": 0.333787,
"_mean": 0.3052500589561977,
"_name": "org.graylog2.shared.buffers.ProcessBuffer.decodeTime",
"_p999": 4.51121,
"_stddev": 0.7182941066091177
The data contains a timestamp field, though.
Any idea what is causing this and how I might fix this?
Thanks!
