Graylog mailutils installation
Deal all,
Should I install the mailutils on graylog server ?
Because i follow the guideline of mail configuration of official document of graylog and set the mail configuration already ,
Unfortunately , i can not transfer the mail successfully.
Are there any errors in the graylog-server log file?
What is your mail configuration?
Hi Ponet
Here is my mail configuration as below
#Email transport
transport_email_hostname = my mail server ip
transport_email_port = 25
#transport_email_use_auth = false
transport_email_from_email = graylog@epistar.com.tw
transport_email_use_tls = true
#transport_email_use_ssl = false
Check if your mail server doesn’t use self-sign certificate, which graylog don’t like.
openssl s_client -starttls smtp -showcerts -connect mail_server_ip:25 -servername mail_server_ip
You should use proper certificate on you smtp server or add your self-sign certificate to graylog trusted ca file.
