haywhai
(Ayoola Ayooluwa)
1
Hi guys, please below is the email configuration in my server.conf file but i still cant receive mails. Please help figure out where the issue is.
When i try the command echo “QUIT” | nc ...** 25** ; it worked fine and i could see the version and all.
But i still get this error persistently
I would appreciate if anyone can put me through.
jochen
(Jochen)
2
You’ve configured the email transport to use SSL but the SMTP server only seems to support plaintext connections of port 25/tcp.
haywhai
(Ayoola Ayooluwa)
3
So what exact change should i make to make it work fine?
jochen
(Jochen)
4
Take a look at the transport_email_* settings and configure them according to your environment.
