Graylog journal utilization and index error
Hi everyone
i installed graylog 5.2 on a G9 Server for a datacenter. gernerally performance is ok but after some days i get some errors about journal utilization and get index error.
OS: Rocky 9.2
Graylog: 5.2
Server: HP G9 (128GB RAM and 56 cores)
cat /etc/graylog/server/server.conf
is_leader = true
password_secret = 0DxGQa…
root_password_sha2 = 7c3a6…
http_bind_address = 10.1.10.11:9000
disabled_retention_strategies = none
allow_highlighting = false
output_batch_size = 500
output_flush_interval = 1
processbuffer_processors = 40
outputbuffer_processors = 20
ring_size = 65536
inputbuffer_ring_size = 65536
inputbuffer_processors = 4
cat /etc/sysconfig/graylog-server
GRAYLOG_SERVER_JAVA_OPTS=“-Xms40g -Xmx40g -server -XX:+UseG1GC -XX:-OmitStackTraceInFastThrow”
GRAYLOG_SERVER_JAVA_OPTS=“$GRAYLOG_SERVER_JAVA_OPTS -Djdk.tls.acknowledgeCloseNotify=true”
GRAYLOG_SERVER_JAVA_OPTS=“$GRAYLOG_SERVER_JAVA_OPTS -Dlog4j2.formatMsgNoLookups=true”
GRAYLOG_SERVER_ARGS=“”
GRAYLOG_COMMAND_WRAPPER=“”
node status image
index error image
notification error
You have a problem on message storage into opensearch. From the sounds of it your index has grown huge, can you post your all your indices, and the rotation settings on them. It’s either not rotating when it should, or not rotating often enough.
Hi Joel
my disk usage in /var/lib/elasticsearch is high (2TB usage from 4.5TB)
curl -X GET “localhost:9200/_cat/shards?v=true&h=index,prirep,shard,store&s=prirep,store&bytes=gb”
You should change the default index set from a 20 day rotation to time size optimized and then set your retention to the length you want. I’m sure those indices are huge, and that’s bad for many different reasons.
thanks for your kind of help
