Graylog inputs start failure
Hi Team
Graylog input stop to fail with the following error-
Input $$$$$$ has failed to start on node $$$$$ for this reason: »Address already in use.«. This means that you are unable to receive any messages from this input. This is mostly an indication for a misconfiguration or an error. You can click here to solve this.
It says Address Already in use, but no other process is using those ports.
Please help.
-Srumith.
Are you sure about that?
Please post the complete configuration of Graylog, the configuration of all inputs, and the output of the following commands on the machines running Graylog.
# netstat -tulpen
# ip addr show
server.conf - graylog
# GRAYLOG CONFIGURATION FILE
# This is the Graylog configuration file. The file has to use ISO 8859-1/Latin-1 character encoding.
# Characters that cannot be directly represented in this encoding can be written using Unicode escapes
# as defined in https://docs.oracle.com/javase/specs/jls/se8/html/jls-3.html#jls-3.3, using the \u prefix.
# For example, \u002c.
# * Entries are generally expected to be a single line of the form, one of the following:
# propertyName=propertyValue
# propertyName:propertyValue
# * White space that appears between the property name and property value is ignored,
#   so the following are equivalent:
# name=Stephen
# name = Stephen
# * White space at the beginning of the line is also ignored.
# * Lines that start with the comment characters ! or # are ignored. Blank lines are also ignored.
# * The property value is generally terminated by the end of the line. White space following the
#   property value is not ignored, and is treated as part of the property value.
# * A property value can span several lines if each line is terminated by a backslash (‘\’) character.
#   For example:
# targetCities=\
#         Detroit,\
#         Chicago,\
#         Los Angeles
#   This is equivalent to targetCities=Detroit,Chicago,Los Angeles (white space at the beginning of lines is ignored).
# * The characters newline, carriage return, and tab can be inserted with characters \n, \r, and \t, respectively.
# * The backslash character must be escaped as a double backslash. For example:
#path=c:\\docs\\doc1
# If you are running more than one instances of Graylog server you have to select one of these
# instances as master. The master will perform some periodical tasks that non-masters won't perform.
is_master = true
# The auto-generated node ID will be stored in this file and read after restarts. It is a good idea
# to use an absolute file path here if you are starting Graylog server from init scripts or similar.
node_id_file = /TECHFUSION/graylog-2.3.2/server/node-id
# You MUST set a secret to secure/pepper the stored user passwords here. Use at least 64 characters.
# Generate one by using for example: pwgen -N 1 -s 96
password_secret = Vw7OY2fdgOkmIL8RK1O6XJ2wshUrJbiyaCU1u5hJESp3CMJdRxvSdaLS1PL7zlrBVetXT0kAzLFk4VHBOBIHJqGblz8fxZMi
root_username = admin
# You MUST specify a hash password for the root user (which you only need to initially set up the
# system and in case you lose connectivity to your authentication backend)
# This password cannot be changed using the API or via the web interface. If you need to change it,
# modify it in this file.
# Create one by using for example: echo -n yourpassword | shasum -a 256
# and put the resulting hash value into the following line
root_password_sha2 = 8c6976e5b5410415bde908bd4dee15dfb167a9c873fc4bb8a81f6f2ab448a918
# Default is empty
#root_email = ""
# Default is UTC
#root_timezone = UTC
plugin_dir = plugin
# REST API listen URI. Must be reachable by other Graylog server nodes if you run a cluster.
# When using Graylog Collectors, this URI will be used to receive heartbeat messages and must be accessible for all collectors.
rest_listen_uri = http://*******:9500/api/
# REST API transport address. Defaults to the value of rest_listen_uri. Exception: If rest_listen_uri
# is set to a wildcard IP address (0.0.0.0) the first non-loopback IPv4 system address is used.
# If set, this will be promoted in the cluster discovery APIs, so other nodes may try to connect on
# this address and it is used to generate URLs addressing entities in the REST API. (see rest_listen_uri)
# You will need to define this, if your Graylog server is running behind a HTTP proxy that is rewriting
# the scheme, host name or URI.
# This must not contain a wildcard address (0.0.0.0).
rest_transport_uri = http://**********:9500/api/
# Enable CORS headers for REST API. This is necessary for JS-clients accessing the server directly.
# If these are disabled, modern browsers will not be able to retrieve resources from the server.
# This is enabled by default. Uncomment the next line to disable it.
#rest_enable_cors = false
# Enable GZIP support for REST API. This compresses API responses and therefore helps to reduce
#rest_enable_gzip = false
# Enable HTTPS support for the REST API. This secures the communication with the REST API with
# TLS to prevent request forgery and eavesdropping. This is disabled by default. Uncomment the
# next line to enable it.
#rest_enable_tls = true
# The X.509 certificate chain file in PEM format to use for securing the REST API.
#rest_tls_cert_file = /path/to/graylog.crt
# The PKCS#8 private key file in PEM format to use for securing the REST API.
#rest_tls_key_file = /path/to/graylog.key
# The password to unlock the private key used for securing the REST API.
#rest_tls_key_password = secret
#rest_max_header_size = 8192
# The maximal length of the initial HTTP/1.1 line in bytes.
#rest_max_initial_line_length = 4096
# The size of the thread pool used exclusively for serving the REST API.
#rest_thread_pool_size = 16
# Enable the embedded Graylog web interface.
# Default: true
web_enable = true
# Web interface listen URI.
# Configuring a path for the URI here effectively prefixes all URIs in the web interface. This is a replacement
# for the application.context configuration parameter in pre-2.0 versions of the Graylog web interface.
web_listen_uri = http://*********:9500/
# Web interface endpoint URI. This setting can be overriden on a per-request basis with the X-Graylog-Server-URL header.
# Default: $rest_transport_uri
#web_endpoint_uri =
# Enable CORS headers for the web interface. This is necessary for JS-clients accessing the server directly.
#web_enable_cors = false
# Enable/disable GZIP support for the web interface. This compresses HTTP responses and therefore helps to reduce
#web_enable_gzip = false
# Enable HTTPS support for the web interface. This secures the communication of the web browser with the web interface
# using TLS to prevent request forgery and eavesdropping.
# This is disabled by default. Uncomment the next line to enable it and see the other related configuration settings.
web_enable_tls =false
# The X.509 certificate chain file in PEM format to use for securing the web interface.
#web_tls_cert_file = /path/to/graylog-web.crt
# The PKCS#8 private key file in PEM format to use for securing the web interface.
#web_tls_key_file = /path/to/graylog-web.key
# The password to unlock the private key used for securing the web interface.
#web_tls_key_password = secret
#web_max_header_size = 8192
#web_max_initial_line_length = 4096
# The size of the thread pool used exclusively for serving the web interface.
#web_thread_pool_size = 16
# requires authentication.
elasticsearch_hosts = http://********:9200
# Maximum amount of time to wait for successfull connection to Elasticsearch HTTP port.
# Default: 10 Seconds
# Default: 60 seconds
# be tore down.
# Default: inf
# Default: 20
#elasticsearch_max_total_connections = 20
# elasticsearch server).
# Default: 2
#elasticsearch_max_total_connections_per_route = 2
# Maximum number of times Graylog will retry failed requests to Elasticsearch.
# Default: 2
#elasticsearch_max_retries = 2
# Enable automatic Elasticsearch node discovery through Nodes Info,
# see https://www.elastic.co/guide/en/elasticsearch/reference/5.4/cluster-nodes-info.html
# WARNING: Automatic node discovery does not work if Elasticsearch requires authentication, e. g. with Shield.
# Default: false
#elasticsearch_discovery_enabled = true
# Filter for including/excluding Elasticsearch nodes in discovery according to their custom attributes,
# see https://www.elastic.co/guide/en/elasticsearch/reference/5.4/cluster.html#cluster-nodes
# Default: empty
#elasticsearch_discovery_filter = rack:42
# Default: 30s
# Default: false
# Graylog will use multiple indices to store documents in. You can configured the strategy it uses to determine
# when to rotate the currently active write index.
# It supports multiple rotation strategies:
#   - "count" of messages per index, use elasticsearch_max_docs_per_index below to configure
#   - "size" per index, use elasticsearch_max_size_per_index below to configure
# valid values are "count", "size" and "time", default is "count"
rotation_strategy = count
#  1w  = 1 week
#  1d  = 1 day
#  12h = 12 hours
#no_retention = false
retention_strategy = delete
# elasticsearch_shards = 5
elasticsearch_shards = 1
# elasticsearch_replicas = 1
elasticsearch_replicas = 0
# Default: graylog-internal
# be enabled with care. See also: http://docs.graylog.org/en/2.1/pages/queries.html
allow_highlighting = false
elasticsearch_cluster_name= graylog
# Global request timeout for Elasticsearch requests (e. g. during search, index creation, or index time-range
# calculations) based on a best-effort to restrict the runtime of Elasticsearch operations.
# Default: 1m
#elasticsearch_request_timeout = 1m
# Default: 1h
# Default: 20
# Default: 1h
index_ranges_cleanup_interval = 1h
output_batch_size = 500
output_flush_interval = 1
processbuffer_processors = 5
outputbuffer_processors = 3
# Possible types:
#  - yielding
#  - sleeping
#  - blocking
#  - busy_spinning
ring_size = 65536
inputbuffer_ring_size = 65536
inputbuffer_processors = 2
# Enable the disk based message journal.
# The directory which will be used to store the message journal. The directory must me exclusively used by Graylog and
# ATTENTION:
message_journal_dir = data/journal
# disabled if not set.
# Length of the interval in seconds in which the alert conditions for all streams should be checked
# and alarms are being sent.
#alert_check_interval = 60
# messages end up.
#stale_master_timeout = 2000
#shutdown_timeout = 30000
# MongoDB connection string
#mongodb_uri = mongodb://grayloguser:secret@localhost:27017,localhost:27018,localhost:27019/graylog
# http://api.mongodb.com/java/current/com/mongodb/MongoOptions.html#threadsAllowedToBlockForConnectionMultiplier
# Drools Rule File (Use to rewrite incoming log messages)
# See: http://docs.graylog.org/en/2.1/pages/drools.html
#rules_file = /etc/graylog/server/rules.drl
# Email transport
#transport_email_enabled = false
#transport_email_hostname = mail.example.com
#transport_email_port = 587
#transport_email_use_auth = true
#transport_email_use_ssl = true
#transport_email_subject_prefix = [graylog]
# Default: 5s
#http_connect_timeout = 5s
# Default: 10s
#http_read_timeout = 10s
# Default: 10s
#http_write_timeout = 10s
#http_proxy_uri =
# Disable the optimization of Elasticsearch indices after index cycling. This may take some load from Elasticsearch
# on heavily used systems with large indices, but it will decrease search performance. The default is to optimize
# cycled indices.
#disable_index_optimization = true
# Optimize the index down to <= index_optimization_max_num_segments. A higher number may take some load from Elasticsearch
# on heavily used systems with large indices, but it will decrease search performance. The default is 1.
#index_optimization_max_num_segments = 1
# The threshold of the garbage collection runs. If GC runs take longer than this threshold, a system notification
# will be generated to warn the administrator about possible problems with the system. Default is 1 second.
#gc_warning_threshold = 1s
# Connection timeout for a configured LDAP server (e. g. ActiveDirectory) in milliseconds.
# Disable the use of SIGAR for collecting system stats
#disable_sigar = false
# The default cache time for dashboard widgets. (Default: 10 seconds, minimum: 1 second)
# Automatically load content packs in "content_packs_dir" on the first start of Graylog.
#content_packs_loader_enabled = true
# The directory which contains content packs which should be loaded on the first start of Graylog.
#content_packs_dir = data/contentpacks
# A comma-separated list of content packs (files in "content_packs_dir") which should be applied on
# the first start of Graylog.
# Default: empty
# For some cluster-related REST requests, the node must query all other nodes in the cluster. This is the maximum number
# of threads available for this. Increase it, if '/cluster/*' requests take long to complete.
# Should be rest_thread_pool_size * average_cluster_size if you have a high number of concurrent users.
elasticsearch.yml
# ======================== Elasticsearch Configuration =========================
# NOTE: Elasticsearch comes with reasonable defaults for most settings.
#       Before you set out to tweak and tune the configuration, make sure you
#       understand what are you trying to accomplish and the consequences.
# The primary way of configuring a node is via this file. This template lists
# the most important settings you may want to configure for a production cluster.
# Please consult the documentation for further information on configuration options:
# https://www.elastic.co/guide/en/elasticsearch/reference/index.html
# ---------------------------------- Cluster -----------------------------------
# Use a descriptive name for your cluster:
#cluster.name: my-application
# ------------------------------------ Node ------------------------------------
# Use a descriptive name for the node:
#node.name: node-1
# Add custom attributes to the node:
#node.attr.rack: r1
# ----------------------------------- Paths ------------------------------------
# Path to directory where to store the data (separate multiple locations by comma):
#path.data: /path/to/data
# Path to log files:
#path.logs: /path/to/logs
# ----------------------------------- Memory -----------------------------------
# Lock the memory on startup:
#bootstrap.memory_lock: true
# Make sure that the heap size is set to about half the memory available
# on the system and that the owner of the process is allowed to use this
# limit.
# Elasticsearch performs poorly when the system is swapping the memory.
# ---------------------------------- Network -----------------------------------
# Set the bind address to a specific IP (IPv4 or IPv6):
#network.host: 192.168.0.1
# Set a custom port for HTTP:
#http.port: 9200
# For more information, consult the network module documentation.
# --------------------------------- Discovery ----------------------------------
# Pass an initial list of hosts to perform discovery when new node is started:
# The default list of hosts is ["127.0.0.1", "[::1]"]
#discovery.zen.ping.unicast.hosts: ["host1", "host2"]
# Prevent the "split brain" by configuring the majority of nodes (total number of master-eligible nodes / 2 + 1):
#discovery.zen.minimum_master_nodes: 3
# For more information, consult the zen discovery module documentation.
# ---------------------------------- Gateway -----------------------------------
# Block initial recovery after a full cluster restart until N nodes are started:
#gateway.recover_after_nodes: 3
# For more information, consult the gateway module documentation.
# ---------------------------------- Various -----------------------------------
# Require explicit names when deleting indices:
#action.destructive_requires_name: true
cluster.name: graylog
node.name: ********
node.master: true
node.data: true
path.conf: /etc/elasticsearch
path.data: /*****/****/data
path.logs: /******/***/logs
network.host: *******
transport.host: localhost
http.port: 9200
discovery.zen.ping.unicast.hosts: ["******:9200"]
# discovery.zen.minimum_master_nodes: 1
Please provide the information I’ve mentioned in Graylog inputs stop to fail.
Thanks could rectify the issue.
for other users it would be helpful to share the solution - not only the problem.
