Graylog input for postgres
Hi. I have been researching a week now and I can’t seem to find anything about receiving logs from database data. Even though it might be easier to use Logstash to get data from the database and send it to Graylog it is not a good option for me. In the Graylog marketplace, I couldn’t find plugin for my needs. Is my only option is to write my own Graylog input plugin in order to make my plan work? What other options I may have?
Have you looked at this?
Yes I looked at it, creating an app with js was my consideration too but it doesn’t fit to my requirements because it should be straight from postgres to my graylog server. Thanks though.
