Graylog HTTP load balancing using netscaler
Having issues load balancing incoming http requests from graylog.domain.com to:
graylognode1.domain.com:9000
graylognode2.domain.com:9000
my server.conf
# Web interface listen URI.
# Configuring a path for the URI here effectively prefixes all URIs in the web interface. This is a replacement
# for the application.context configuration parameter in pre-2.0 versions of the Graylog web interface.
web_listen_uri = http://graylognode1.domain.com:9000/
# Web interface endpoint URI. This setting can be overriden on a per-request basis with the X-Graylog-Server-URL header.
# Default: $rest_transport_uri
web_endpoint_uri = http://graylog.domain.com:9000/api/
this configuration works fine under HA proxy however.
Here is the config from the NetScaler:
add lb vserver GRAYLOG SYSLOGUDP -persistenceType NONE -lbMethod AUDITLOGHASH -backupLBMethod LEASTCONNECTION -cltTimeout 120
add lb vserver GRAYLOG2 UDP 172.16.104.100 514 -persistenceType NONE -cltTimeout 120
add lb vserver GRAYLOG_WEB HTTP 172.16.104.100 80 -persistenceType NONE -cltTimeout 180
add audit syslogAction GRAYLOG -lbVserverName GRAYLOG -logLevel ALL
add audit syslogPolicy “GRAYLOG POLICY” true GRAYLOG
bind lb vserver GRAYLOG2 nor1emslog02 -weight 100
bind lb vserver GRAYLOG2 nor1emslog01
bind lb vserver GRAYLOG_WEB nor1emslog01_WEB
bind lb vserver GRAYLOG_WEB nor1emslog02_WEB -weight 99
add lb monitor GRAYLOG HTTP-ECV -send “GET /api/system/lbstatus” -recv ALIVE -LRTM DISABLED -destPort 9000
bind service nor1emslog01 -monitorName GRAYLOG
bind service nor1emslog02 -monitorName GRAYLOG
bind audit syslogGlobal -policyName “GRAYLOG POLICY” -priority 100
Please elaborate on the issue you have. It’s not clear from just the configuration snippets you’ve posted.
when you go to http://graylog.domain.com you don’t get traffic passing through
What does that mean exactly?
Which component in your setup is blocking network traffic and how did you test it?
This has been fixed, it was a net scaler configuration issue
