I am able to get my forwarder to connect to my Graylog server on a VPS, which has a letsencrypt ssl cert installed, without TLS enabled. When I enable forwarder_grpc_tls_trust_chain_cert_file = /home//fullchain.pem on the forwarder the forwarder service will not start, it starts for a moment and then fails with exit code 1.
I’m unsure what I am doing wrong here, am I using the right certificate? I’ve tried changing the owner to root and changing the permissions to 664, I just get the same issue.
If I run with TLS enabled on the forwarder starts but does not connect to the server.
Any insight would be greatly appreciated.
OS Information: Ubuntu server 22.04
Package Version: 5.1
Can be provided.
