Graylog first problem's
Hi, i have installed Graylog with elasticearch and mongodb in a server Ubuntu 18, but i can’t see log’s i created three Input’s 02 linux server and 01 windows, and i see this error
  • Deflector exists as an index and is not an alias
  • Elasticsearch cluster is yellow.** Shards: 5 active, 0 initializing, 0 relocating, 5 unassigned,
I select in tab “Search” appearme Nothing found what’s wrong?
you have two problems:
What Version of Elasticsearch did you use? have you seen this in the docs? http://docs.graylog.org/en/2.4/pages/faq.html#how-do-i-fix-the-deflector-exists-as-an-index-and-is-not-an-alias-error-message
