Graylog filled my disk, how do I delete some data?
So graylog filled up my root completly, the webpages doesn’t load anymore (/ and /api).
How can I clean some data (I don’t really care about it, but I’d like to retain some, mostly recent, data)?
Thank you,
Alexis
He @ave314
without knowledge about your installation I can only give the advice:
  • select some indices that can be deleted
  • delete them from elasticsearch via api (of elasticsearch)
  • start Graylog and recalculate the index size ( System > Indices)
Hey jan,
The web pages doesn’t load.
My installation is on a Centos 7 VM, installed with the docs installation guide.
What I am taking out of your response :
I need to find the command line that will delete some indices from elasticsearch.
EDIT :
This reboot allowed me access to the web interface. I still went with those command :
First aid: check which indices are present:
curl http://localhost:9200/_cat/indices
Then delete the oldest indices (you should not delete all)
curl -XDELETE http://localhost:9200/graylog_1
curl -XDELETE http://localhost:9200/graylog_2
curl -XDELETE http://localhost:9200/graylog_3
Hi @ave314,
I always move my data to a separate partition attached to my system as per Graylog manual,.
Just a tip from someone who learned this mistake early on as well.
Kind Regards
Jake
