Graylog does not start
Hello everyone,
I have installed and configured a graylog on a machine with nginx revrese proxy and filebeat to other machine with sidecar. Everything worked fine and I could saw logs but after that I tried to install and configure Geolocation. First I created an input, rules and pipeline for that just like guide but when it did not started with problem file permission denied. It was the database file for geolocation which is geoIp. So I gave privillige to that file and try restarted graylog. After restart graylog went down and whatever I tried it did not active again. Even stopped writing logs until I tried to start it from directly to the bash file /usr/share/graylog-server/bin/graylog-server. I read all the related topics and tried everthing I know but could not solve it. Elasticsearch, mongodb, nginx and filebeat active and running.
Graylog Logs
Blockquote
2020-12-10T09:36:23.377+03:00 ERROR [IndexRotationThread] Uncaught exception in periodical
org.graylog.shaded.elasticsearch7.org.elasticsearch.ElasticsearchException: An error occurred:
at org.graylog.storage.elasticsearch7.ElasticsearchClient.exceptionFrom(ElasticsearchClient.java:122) ~[?:?]
at org.graylog.storage.elasticsearch7.ElasticsearchClient.execute(ElasticsearchClient.java:92) ~[?:?]
at org.graylog.storage.elasticsearch7.ElasticsearchClient.execute(ElasticsearchClient.java:85) ~[?:?]
at org.graylog.storage.elasticsearch7.ClusterAdapterES7.isConnected(ClusterAdapterES7.java:161) ~[?:?]
at org.graylog2.indexer.cluster.Cluster.isConnected(Cluster.java:115) ~[graylog.jar:?]
at org.graylog2.periodical.IndexRotationThread.doRun(IndexRotationThread.java:72) ~[graylog.jar:?]
at java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:511) [?:1.8.0_275]
at java.util.concurrent.FutureTask.runAndReset(FutureTask.java:308) [?:1.8.0_275]
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.access$301(ScheduledThreadPoolExecutor.java:180) [?:1.8.0_275]
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.run(ScheduledThreadPoolExecutor.java:294) [?:1.8.0_275]
at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1149) [?:1.8.0_275]
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:624) [?:1.8.0_275]
at java.lang.Thread.run(Thread.java:748) [?:1.8.0_275]
Caused by: java.net.ConnectException: Connection refused
at org.graylog.shaded.elasticsearch7.org.elasticsearch.client.RestClient.extractAndWrapCause(RestClient.java:849) ~[?:?]
at org.graylog.shaded.elasticsearch7.org.elasticsearch.client.RestClient.performRequest(RestClient.java:259) ~[?:?]
at org.graylog.shaded.elasticsearch7.org.elasticsearch.client.RestClient.performRequest(RestClient.java:246) ~[?:?]
at org.graylog.shaded.elasticsearch7.org.elasticsearch.client.RestHighLevelClient.internalPerformRequest(RestHighLevelClient.java:1613) ~[?:?]
at org.graylog.shaded.elasticsearch7.org.elasticsearch.client.RestHighLevelClient.performRequest(RestHighLevelClient.java:1583) ~[?:?]
at org.graylog.shaded.elasticsearch7.org.elasticsearch.client.RestHighLevelClient.performRequestAndParseEntity(RestHighLevelClient.java:1553) ~[?:?]
at org.graylog.shaded.elasticsearch7.org.elasticsearch.client.ClusterClient.health(ClusterClient.java:130) ~[?:?]
at org.graylog.storage.elasticsearch7.ClusterAdapterES7.lambda$isConnected$9(ClusterAdapterES7.java:161) ~[?:?]
at org.graylog.storage.elasticsearch7.ElasticsearchClient.execute(ElasticsearchClient.java:90) ~[?:?]
… 12 more
at sun.nio.ch.SocketChannelImpl.checkConnect(Native Method) ~[?:1.8.0_275]
at sun.nio.ch.SocketChannelImpl.finishConnect(SocketChannelImpl.java:716) ~[?:1.8.0_275]
at org.graylog.shaded.elasticsearch7.org.apache.http.impl.nio.reactor.DefaultConnectingIOReactor.processEvent(DefaultConnectingIOReactor.java:174) ~[?:?]
at org.graylog.shaded.elasticsearch7.org.apache.http.impl.nio.reactor.DefaultConnectingIOReactor.processEvents(DefaultConnectingIOReactor.java:148) ~[?:?]
at org.graylog.shaded.elasticsearch7.org.apache.http.impl.nio.reactor.AbstractMultiworkerIOReactor.execute(AbstractMultiworkerIOReactor.java:351) ~[?:?]
at org.graylog.shaded.elasticsearch7.org.apache.http.impl.nio.conn.PoolingNHttpClientConnectionManager.execute(PoolingNHttpClientConnectionManager.java:221) ~[?:?]
at org.graylog.shaded.elasticsearch7.org.apache.http.impl.nio.client.CloseableHttpAsyncClientBase$1.run(CloseableHttpAsyncClientBase.java:64) ~[?:?]
… 1 more
2020-12-10T09:36:24.056+03:00 ERROR [IndexFieldTypePollerPeriodical] Couldn’t update field types for index set <Default index set/5fbf919c72ad25624fb1fdaa>
at org.graylog.storage.elasticsearch7.IndicesAdapterES7.resolveAlias(IndicesAdapterES7.java:135) ~[?:?]
at org.graylog2.indexer.indices.Indices.aliasTarget(Indices.java:146) ~[graylog.jar:?]
at org.graylog2.indexer.MongoIndexSet.getActiveWriteIndex(MongoIndexSet.java:204) ~[graylog.jar:?]
at org.graylog2.indexer.fieldtypes.IndexFieldTypePollerPeriodical.lambda$schedule$4(IndexFieldTypePollerPeriodical.java:216) ~[graylog.jar:?]
at org.graylog.shaded.elasticsearch7.org.elasticsearch.client.IndicesClient.getAlias(IndicesClient.java:1315) ~[?:?]
Blockquote
I solved it by giving permissions to upper graylog proccess after checkhing with namei -l command
