Hi!
After the upgrade of Graylog 5.0.13 to 5.1.13, the service does start, but never open port 9000 and does not join the cluster.
The logfile ends with: INFO [ElasticsearchVersionProvider] Elasticsearch cluster is running OpenSearch:1.3.14
Prior to the upgrade, the next line did appear after 2 seconds:
INFO [ProcessBuffer] Initialized ProcessBuffer with ring size <65536> and wait strategy .
Ubuntu 20.04 without SELinux
5.0.13 > 5.1.13
3-node-cluster
Opensearch 1.3.4 backend, MongoDB 5.0.14, OpenJDK 17.0.9
The service seems to be fully started, but Port 900 is still not opened:
# ss -lntp | grep ‘:9000’ || true
- Checked Opensearch and MongoDB (everything fine)
- added http_publish_uri and http_external_uri
- added “is_leader = true” to one of the nodes (and false to the others)
- Checked, that port is free, when Graylog starts
- Deleted Journal (was recreated on start)
Can you give me a hint on what is blocking the start? I did not find any hint in the logs.
Thank you for your help!
