Graylog 5.0.6 fails to bind to port 9000
Graylog 5 starts and all of it’s dependancies but doesn’t bind to tcp port 9000.
tcp6 0 0 ip6-localhost:9200 [::]:* LISTEN 1177/java
tcp6 0 0 localhost:9200 [::]:* LISTEN 1177/java
tcp6 0 0 localhost:9300 [::]:* LISTEN 1177/java
tcp6 0 0 ip6-localhost:9300 [::]:* LISTEN 1177/java
It only happens after a recent update to Ubuntu 22.04.
I can go back to my last TimeShift snapshot and Graylog starts and binds to tcp port 9000.
  • OS Information:
    Ubuntu 22.04
  • Package Version:
    5.0.6
    Graylog.log messages
    root@ces-linux-01:~# grep ERROR /var/log/elasticsearch/graylog.log
[2023-04-21T08:22:18,005][ERROR][o.e.i.g.GeoIpDownloader ] [ces-linux-01] exception during geoip databases update
[2023-04-21T08:58:47,764][ERROR][o.e.i.g.GeoIpDownloader ] [ces-linux-01] exception during geoip databases update
root@ces-linux-01:~# grep WARNING /var/log/elasticsearch/graylog.log
root@ces-linux-01:~# grep WARN /var/log/elasticsearch/graylog.log
[2023-04-21T08:20:33,720][WARN ][o.e.c.InternalClusterInfoService] [ces-linux-01] failed to retrieve stats for node [L8TAII3STuKssvoatbKtQA]: [ces-linux-01][127.0.0.1:9300][cluster:monitor/nodes/stats[n]]
[2023-04-21T08:20:33,744][WARN ][o.e.c.InternalClusterInfoService] [ces-linux-01] failed to retrieve shard stats from node [L8TAII3STuKssvoatbKtQA]: [ces-linux-01][127.0.0.1:9300][indices:monitor/stats[n]]
[2023-04-21T08:22:13,843][WARN ][o.e.b.BootstrapChecks ] [ces-linux-01] the default discovery settings are unsuitable for production use; at least one of [discovery.seed_hosts, discovery.seed_providers, cluster.initial_master_nodes] must be configured
[2023-04-21T08:22:16,487][WARN ][o.e.x.s.s.SecurityStatusChangeListener] [ces-linux-01] Elasticsearch built-in security features are not enabled. Without authentication, your cluster could be accessible to anyone. See Set up minimal security for Elasticsearch | Elasticsearch Guide [7.17] | Elastic to enable security.
[2023-04-21T08:58:46,029][WARN ][o.e.b.BootstrapChecks ] [ces-linux-01] the default discovery settings are unsuitable for production use; at least one of [discovery.seed_hosts, discovery.seed_providers, cluster.initial_master_nodes] must be configured
[2023-04-21T08:58:47,203][WARN ][o.e.x.s.s.SecurityStatusChangeListener] [ces-linux-01] Elasticsearch built-in security features are not enabled. Without authentication, your cluster could be accessible to anyone. See Set up minimal security for Elasticsearch | Elasticsearch Guide [7.17] | Elastic to enable security.
Graylog server.log
2023-04-21T08:20:30.802-07:00 ERROR [Messages] Caught exception during bulk indexing: ElasticsearchException{message=ElasticsearchException[An error occurred: ]; nested: ConnectException[Connection refused]; nested: ConnectException[Connection refused];, errorDetails=}, retrying (attempt #1).
2023-04-21T08:20:30.809-07:00 ERROR [Messages] Caught exception during bulk indexing: ElasticsearchException{message=ElasticsearchException[An error occurred: ]; nested: ConnectException[Connection refused]; nested: ConnectException[Connection refused];, errorDetails=}, retrying (attempt #2).
2023-04-21T08:20:30.814-07:00 ERROR [Messages] Caught exception during bulk indexing: ElasticsearchException{message=ElasticsearchException[An error occurred: ]; nested: ConnectException[Connection refused]; nested: ConnectException[Connection refused];, errorDetails=}, retrying (attempt #3).
2023-04-21T08:20:30.824-07:00 ERROR [Messages] Caught exception during bulk indexing: ElasticsearchException{message=ElasticsearchException[An error occurred: ]; nested: ConnectException[Connection refused]; nested: ConnectException[Connection refused];, errorDetails=}, retrying (attempt #4).
2023-04-21T08:20:30.842-07:00 ERROR [Messages] Caught exception during bulk indexing: ElasticsearchException{message=ElasticsearchException[An error occurred: ]; nested: ConnectException[Connection refused]; nested: ConnectException[Connection refused];, errorDetails=}, retrying (attempt #5).
2023-04-21T08:20:30.876-07:00 ERROR [Messages] Caught exception during bulk indexing: ElasticsearchException{message=ElasticsearchException[An error occurred: ]; nested: ConnectException[Connection refused]; nested: ConnectException[Connection refused];, errorDetails=}, retrying (attempt #6).
2023-04-21T08:20:30.942-07:00 ERROR [Messages] Caught exception during bulk indexing: ElasticsearchException{message=ElasticsearchException[An error occurred: ]; nested: ConnectException[Connection refused]; nested: ConnectException[Connection refused];, errorDetails=}, retrying (attempt #7).
2023-04-21T08:20:31.072-07:00 ERROR [Messages] Caught exception during bulk indexing: ElasticsearchException{message=ElasticsearchException[An error occurred: ]; nested: ConnectException[Connection refused]; nested: ConnectException[Connection refused];, errorDetails=}, retrying (attempt #8).
2023-04-21T08:20:31.330-07:00 ERROR [Messages] Caught exception during bulk indexing: ElasticsearchException{message=ElasticsearchException[An error occurred: ]; nested: ConnectException[Connection refused]; nested: ConnectException[Connection refused];, errorDetails=}, retrying (attempt #9).
2023-04-21T08:20:31.844-07:00 ERROR [Messages] Caught exception during bulk indexing: ElasticsearchException{message=ElasticsearchException[An error occurred: ]; nested: ConnectException[Connection refused]; nested: ConnectException[Connection refused];, errorDetails=}, retrying (attempt #10).
2023-04-21T08:20:32.870-07:00 ERROR [Messages] Caught exception during bulk indexing: ElasticsearchException{message=ElasticsearchException[An error occurred: ]; nested: ConnectException[Connection refused]; nested: ConnectException[Connection refused];, errorDetails=}, retrying (attempt #11).
2023-04-21T08:20:34.920-07:00 ERROR [Messages] Caught exception during bulk indexing: ElasticsearchException{message=ElasticsearchException[An error occurred: ]; nested: ConnectException[Connection refused]; nested: ConnectException[Connection refused];, errorDetails=}, retrying (attempt #12).
2023-04-21T08:20:35.890-07:00 ERROR [ClusterAdapterES7] An error occurred: (Connection refused)
2023-04-21T08:20:35.984-07:00 ERROR [VersionProbe] Unable to retrieve version from Elasticsearch node: Failed to connect to /127.0.0.1:9200. - Connection refused.
2023-04-21T08:20:39.019-07:00 ERROR [Messages] Caught exception during bulk indexing: ElasticsearchException{message=ElasticsearchException[An error occurred: ]; nested: ConnectException[Connection refused]; nested: ConnectException[Connection refused];, errorDetails=}, retrying (attempt #13).
2023-04-21T08:20:40.985-07:00 ERROR [VersionProbe] Unable to retrieve version from Elasticsearch node: Failed to connect to /127.0.0.1:9200. - Connection refused.
2023-04-21T08:20:45.986-07:00 ERROR [VersionProbe] Unable to retrieve version from Elasticsearch node: Failed to connect to /127.0.0.1:9200. - Connection refused.
2023-04-21T08:20:47.213-07:00 ERROR [Messages] Caught exception during bulk indexing: ElasticsearchException{message=ElasticsearchException[An error occurred: ]; nested: ConnectException[Connection refused]; nested: ConnectException[Connection refused];, errorDetails=}, retrying (attempt #14).
2023-04-21T08:20:50.987-07:00 ERROR [VersionProbe] Unable to retrieve version from Elasticsearch node: Failed to connect to /127.0.0.1:9200. - Connection refused.
2023-04-21T08:20:55.989-07:00 ERROR [VersionProbe] Unable to retrieve version from Elasticsearch node: Failed to connect to /127.0.0.1:9200. - Connection refused.
2023-04-21T08:20:57.104-07:00 ERROR [InMemoryRolePermissionResolver] Could not find roles collection, no user roles updated.
2023-04-21T08:20:57.804-07:00 ERROR [JobSchedulerService] Error running job execution engine
2023-04-21T08:20:57.914-07:00 ERROR [NodePingThread] Uncaught exception in Periodical
2023-04-21T08:20:57.983-07:00 ERROR [MongoDBProcessingStatusRecorderService] Couldn’t persist processing status
Google searches for the log entry but nothing that works.
Some assist how to debug the issue or suggestion on what could be the issue.
Here is my graylog server configuration.
root@ces-linux-01:~# cat /etc/graylog/server/server.conf | egrep -v “^\s*(#|$)”
is_leader = true
password_secret = REDACTED
root_password_sha2 = REDACTED
root_timezone = PST8PDT
rotation_strategy = count
retention_strategy = delete
elasticsearch_shards = 4
elasticsearch_replicas = 0
allow_highlighting = false
output_batch_size = 500
output_flush_interval = 1
processbuffer_processors = 5
outputbuffer_processors = 3
ring_size = 65536
inputbuffer_ring_size = 65536
inputbuffer_processors = 2
integrations_scripts_dir = /usr/share/graylog-server/scripts
It binds to the ipv6 address even when it comes online. Don’t know if that has anything to do with it.
@ces-linux-01:~$ sudo netstat -tulp | grep java
tcp6 0 0 localhost:9200 [::]:* LISTEN 1171/java
tcp6 0 0 localhost:9000 [::]:* LISTEN 1175/java
tcp6 0 0 localhost:9300 [::]:* LISTEN 1171/java
tcp6 0 0 [::]:shell [::]:* LISTEN 1175/java
tcp6 0 0 ip6-localhost:9200 [::]:* LISTEN 1171/java
tcp6 0 0 ip6-localhost:9300 [::]:* LISTEN 1171/java
tcp6 0 0 [::]:12201 [::]:* LISTEN 1175/java
udp6 0 0 [::]:syslog [::]:* 1175/java
udp6 0 0 [::]:1514 [::]:* 1175/java
One more detail, it is behind an nginx proxy. That log just has an error no upstream neighbor or something.
Hey @flyshoo
I dont see this configured in your file
http_bind_address = 127.0.0.1:9000
Or you can use this since your behind nginx proxy.
@gsmith thanks for the suggestion.
I added that line and disabled elasticsearch version check because it was complaining failing to determine version. Even set the major version of elasticsearch.
Still fails to bind to tcp port 9000 on any address.
is_leader = true
elasticsearch_disable_version_check = true
elasticsearch_version = 7
ring_size = 65536
I rolled back the updates and everything is working. I’m going to do a binary search for the offending update and go from there.
Thanks, for your views and I’ll open another ticket after I find the update.
Flyshoo
Appears the new version of graylog is the issue.
Is it possible to start graylog in debug mode?
Do these messages from systemctl mean anything?
Apr 23 20:01:04 ces-linux-01 graylog-server[2706]: at com.google.inject.internal.Errors.throwCreationExceptionIfErrorsExist(Errors.java:568)
Apr 23 20:01:04 ces-linux-01 graylog-server[2706]: at com.google.inject.internal.InternalInjectorCreator.injectDynamically(InternalInjectorCreator.java:190)
Apr 23 20:01:04 ces-linux-01 graylog-server[2706]: at com.google.inject.internal.InternalInjectorCreator.build(InternalInjectorCreator.java:113)
Apr 23 20:01:04 ces-linux-01 graylog-server[2706]: at com.google.inject.Guice.createInjector(Guice.java:87)
Apr 23 20:01:04 ces-linux-01 graylog-server[2706]: at org.graylog2.shared.bindings.GuiceInjectorHolder.createInjector(GuiceInjectorHolder.java:34)
Apr 23 20:01:04 ces-linux-01 graylog-server[2706]: at org.graylog2.bootstrap.CmdLineTool.setupInjector(CmdLineTool.java:502)
Apr 23 20:01:04 ces-linux-01 graylog-server[2706]: at org.graylog2.bootstrap.CmdLineTool.doRun(CmdLineTool.java:306)
Apr 23 20:01:04 ces-linux-01 graylog-server[2706]: at org.graylog2.bootstrap.CmdLineTool.run(CmdLineTool.java:260)
Apr 23 20:01:04 ces-linux-01 graylog-server[2706]: at org.graylog2.bootstrap.Main.main(Main.java:45)
Ok, I resolved the issue. The update wrote over the systemd file. I’m running the service as root. I know that is not recommended but it works.
Hey @flyshoo
Sorry for the late reply. glad to see you resolved it :+1:
