Description of your problem
Just trying to run this with my volume mapped to a local share that has permission UID and GID set to user 1100. When I docker run the image, it will generate these 3 errors in the log:
Error1:
Couldn’t load configuration: Properties file /user/share/graylog/data/config/graylog.conf
Error2:
Error StatusLogger File not found in file system or classpath: /usr/share/graylog/data/config/log4j2.xml
Error3:
Error StatusLogger Reconfiguration failed: No configuration found for ?? at null in null
the mapped folder that I have on the docker host does create empty folders: config, content packs, journal, log, plugin
I am running this docker run command:
docker run
–name graylog1
-v /usr/local/etc/graylog1:/usr/share/graylog/data
–link es1
–link es2
–link es3
–link mongo1
-e GRAYLOG_HTTP_EXTERNAL_URI=“http://172.16.15.47:9000/”
-p 9000:9000
-p 12201:12201/udp
–network graylog
–restart=unless-stopped
-d graylog/graylog:4.1.3
Description of steps you’ve taken to attempt to solve the issue
I have tried to ensure the permission are correct
Environmental information
Ubuntu
Operating system information
- RHEL
- CentOS
- Ubuntu
- Debian
- Containers (e.g., Docker, Kubernetes, etc.)
- FreeBSD
- Windows
- Other (e.g., using config management like Chef, Puppet, Ansible or Salt to deploy Graylog)
Package versions
- Graylog
- MongoDB
- Elasticsearch
- Service logs, configuration, and environment variables
- See the docs site for all file locations
NOTE: For all container-based deployments, please include your full, redacted YAML configuration file
NOTE: When posting log output or code snippets (e.g., JSON, YAML, etc.), please surround your code with three backticks like so:
``` Your code goes here ```
For longer code or configuration bits, please enclose your snippet in a summary block like this:
Summary of your code snippet or config here
Your code goes inside the triple backticks
