Graylog docker installation
I installed graylog docker, I do not recover the logs of my firewall while with the appliance I see the logs arrived
Wht’s the problem ?
Best Regards,
Bilifive
Please describe exactly what you’ve done, including the full configuration of all relevant components and all commands you’ve executed including their complete output, and what you’re trying to achieve.
i’ve installed Graylog Docker on Ubuntu server on Hyper-V , i followed the offical tutorial for installation.
$ docker run --name mongo -d mongo:3
$ docker run --name elasticsearch \
    -e "http.host=0.0.0.0" -e "xpack.security.enabled=false" \
    -d docker.elastic.co/elasticsearch/elasticsearch:5.6.2
$ docker run --link mongo --link elasticsearch \
    -p 9000:9000 -p 12201:12201 -p 514:514 \
    -e GRAYLOG_WEB_ENDPOINT_URI="http://My-Ip-Address:9000/api" \
    -d graylog/graylog:2.4.0-1
and i access to my web interface, i created an input
But the problem is: i don’t receive logs.
Best regards,
You’re exposing only TCP ports with your Docker command but you’re trying to use UDP-based inputs.
See https://docs.docker.com/network/links/#connect-using-network-port-mapping for details.
Ok now it’s works, but i can’t show received messages
When i clicked on show received messages its always on loading
Check the logs of your Graylog and Elasticsearch containers.
