I had a working Graylog instance working on an Ubuntu 18.04 install. After turning off my FreeNAS machine to add new drives and create a new, separate pool, Graylog no longer launches. I get a refused to connect message.
I’ve also reverted to several prior snapshots with no difference.
Java, Mongo, ElasticSearch, Graylog, and Graylog Sidecar all show Running when I do a status command.
Journal displays:
Oct 02 20:24:00 graylog systemd[1]: graylog-server.service: Main process exited, code=exited, status=1/FAILURE
Oct 02 20:24:00 graylog systemd[1]: graylog-server.service: Failed with result 'exit-code'.
Oct 02 20:24:01 graylog filebeat[961]: 2020-10-02T20:24:01.318-0500 INFO [monitoring] log/log.go:145 Non-zero metrics in the last 30s {"monitoring": {"metrics": {"beat":{"cpu":
Oct 02 20:24:07 graylog graylog-sidecar[1108]: time="2020-10-02T20:24:07-05:00" level=error msg="[UpdateRegistration] Failed to report collector status to server: Put http://192.168.1.25:9000/api/sidecars/2ee812
Oct 02 20:24:11 graylog systemd[1]: graylog-server.service: Service hold-off time over, scheduling restart.
Oct 02 20:24:11 graylog systemd[1]: graylog-server.service: Scheduled restart job, restart counter is at 67.
-- Subject: Automatic restarting of a unit has been scheduled
-- Defined-By: systemd
-- Support: http://www.ubuntu.com/support
And syslog displays:
Oct 2 20:24:37 graylog graylog-sidecar[1108]: time="2020-10-02T20:24:37-05:00" level=error msg="[UpdateRegistration] Failed to report collector status to server: Put http://192.168.1.25:9000/api/sidecars/2ee81295-e283-45ba-9471-09d9c0b0c74e: dial tcp 192.168.1.25:9000: connect: connection refused
No firewall rules (this is a local network)
Chain INPUT (policy ACCEPT)
target prot opt source destination
Chain FORWARD (policy ACCEPT)
Chain OUTPUT (policy ACCEPT)
Sidecar yaml has the correct IP:
# The URL to the Graylog server API.
server_url: “http://192.168.1.25:9000/api/”
So I’ve just reached a point where I need to ask for help.
All my previous searches led to misconfigured IPs and firewalls, but I think I’ve covered that. Any ideas?
